Wid rimmed 29er fro...
[Closed] Wid rimmed 29er front wheel, ready built?
[#6509750]
Fancy the idea of a 29+ tyre on the front of my pinnacle ramin one. They currently have 19mm rims and I fancy something bigger at the front. I want to have two wheels, the spec one and maybe a 29+ too so I can switch. Are there any ready built wheels up to the job at a decent price or should I consider having one built. The Chris Holm xc and freeride rims look a decent option at 38 and 45mm respectively and a lot cheaper than the rabbit hole, they are made for unicycles however. Opinions welcome as I'm a bit out of my depth here.
Posted : 25/09/2014 6:11 pm
[url= http://www.light-bicycle.com/beadless-carbon-29er-wheelset-35mm-wide-tubeless-compatible-hand-built-mtb-29er-wheels.html#.VCRURu8tBaQ ]Light Bicycle[/url] do a 35mm rim.. various build options.
Posted : 25/09/2014 6:42 pm
Wide lightning?
Posted : 25/09/2014 7:37 pm
Velocity blunt 35 on your choice of Hub at just riding along will fit the bill nicely for that. Doubt it would be too expensive either.
Posted : 25/09/2014 7:39 pm
Just checked out the light bicycle rims and they only do the 35mm in a pair. Couldn't find the wide lightning wheels and the velocity blunt is out of stock at the only place I found it. I found these last night but have no idea if they are compatible with a 100mm mtb hub
http://www.unicycle.uk.com/29-kris-holm-xc-rim.html?gclid=CLmE4q6_-sACFUsOwwodH5wAkA
I wonder if the offset eyelets are an issue?
Posted : 25/09/2014 7:59 pm
Dually rim is 45mm sam@singular has some wheelsets with that rim for sale
Posted : 25/09/2014 8:01 pm
[quote=paulgeorge]Just checked out the light bicycle rims and they only do the 35mm in a pair.
I'm sure they'd do a single wheel if you asked them - they are normally very accommodating!
Just ordered a Dually today, for "Knarding up" the front of my SIR.9.
(Charliethebikemonger terminology).
Have a drawer that's seemingly full of spare front hubs, (& a set of spokes within a mm of the right length), so should be able to sort a build. 🙂
Looked at the Blunt35 but wanted to get the front like the Krampus I tried.
If you go with a Blunt you should get a front built for £120 or so.
Posted : 25/09/2014 10:09 pm
