Whyte T129 increase...
[Closed] Whyte T129 increase front travel ?
[#7115679]
CSU on OEM Fox creaking in the market for new forks . Any recommendations , may increase travel , looking at 130 or 140 Rev's . With only 10mm increase I'm thinking it won't make the front too slack.
Posted : 07/06/2015 2:33 pm
10mm increase in travel will slacken the head angle by about 1 degree. I've run slightly longer than spec forks on many bikes and it was fine. I believe more than 10mm and it starts significantly negatively affecting the handling and geometry.
Posted : 07/06/2015 3:23 pm
IIRC +10mm of travels equal an extra half a degree of headangle. TBH I demo'd a t-129 & measured the a-c & was convinced it was longer than normal (or a 140mm fork). Again I'd say go for it, it hardly going to change the bikes handling that much
Posted : 07/06/2015 3:30 pm
I run 140 revs on mine...its fine ..A little more wander on the climbs. ..but nothing to worry about
Posted : 07/06/2015 3:41 pm
Thanks for the correction, z1ppy 🙂
Posted : 07/06/2015 4:05 pm
I bought a pair of 140mm Pikes to replace the horrible Fox that came on my Fuel 29er. I intended to put a new air assembly in and reduce the travel to 130/120mm but it feels fine so don't think I'll bother. The Trek was relatively steep anyway so I'm liking the slacker head angle. It raised the BB a bit so that's something to bear in mind.
Posted : 07/06/2015 4:16 pm
 st
I'm one ride in after building up a 2013 model and I swapped the stock Rebas for my existing 140mm Revs and am quite happy so far.
Posted : 07/06/2015 4:30 pm
I stuck 140mm pikes with the max offset option, not that much taller but turned it into a far more capable machine.
Posted : 07/06/2015 10:02 pm
