Whyte G150S What Be...
[Closed] Whyte G150S What Bearing?
[#8466434]
Needing to replace swing arm bearings rather quickly and don't have time to make the trip to the shop I bought it from for the free bearing replacement, anybody know what no of bearing I need and where could I buy it from.
Any help much appreciated
Posted : 23/04/2017 3:30 pm
Kp5ax bearing is the one you need. It's an imperial size bearing and a bugger to find in stock. Not cheap either at around £20 a bearing. Trust me go for the free replacement option.
Full technical manual is available here
Posted : 23/04/2017 5:57 pm
Yeh might be easier going for the warranty replacement, bit annoying as they replaced the top bearings in December but said lower ones wer fine! Free bearings but labour was £40
Posted : 23/04/2017 6:58 pm
My lbs said they would fit them for free, but amount 2 weeks to get a slot in the workshop. TBH it's an easy enough job to do yourself. See if your dealer will supply the bearings foc and you return the faulty ones. Some do some don't, my lbs did
Posted : 23/04/2017 7:21 pm
