Whyte front hub bea...
[Closed] Whyte front hub bearings
[#9443582]
Does anyone know which bearings I need for my Whyte T-129 '14 model front hub? It is Whyte branded. Also, has anyone changed these bearings? Any tips? I'm assuming that the end caps have to be prised off somehow, but it doesn't look easy without damaging them.
Posted : 18/07/2017 9:39 pm
No-one?
Posted : 24/07/2017 2:28 pm
Call them...?
Posted : 24/07/2017 2:34 pm
Pictures might help as I'd wager the hubs are not unique to whyte.
Posted : 24/07/2017 3:04 pm
Are they 15mm through axle? If so, the outer caps usually just prise off and then I'll typically use a semi-blind puller to get the old ones out and measure 'em up. Literally, 5 mins job. If you live around my neck of the woods, I'd be happy to help you out here - PM me if you want more.
Posted : 24/07/2017 4:17 pm
Yes, they are 15mm through axle. So long as I know I can just prise the end caps off, I'm OK. I didn't want to damage anything.
Posted : 24/07/2017 7:12 pm
No problem. Good luck and report back 🙂
Posted : 24/07/2017 8:14 pm
