[i]chainsuck[/i] is the act of the chain sticking to/climbing up the front chainring.
What you're calling chainsuck is the chain hitting the frame [i]after the chainsuck has already happened[/i].
richc - Member
OK then andyl, how does that explain exactly the same chainset, chain, cassette being installed on another frame by the same person not experiencing chainstuck, in exactly the same conditions?ie: the only variable which is different is the frame.
Badly set up on one frame. Better on the other OR just the frame is knocking the chain off the ring in better place. As I said earlier, the frame dictates where and if the chain actually gets jammed. As wwaswas says - the act of chainsuck is the chain getting stuck on the rings.
Also where all the variables the same? Rear dérailleur at the correct angle. Cable outer leading to it free to move okay? Chain the correct length?
