Is it a wattage issue or cable? I'm not sure if I got a specific charger for it?
Charging it from a standard wall brick or some smart device (that is possibly turning off when the current draw drops and it thinks it's full?)
I use any cable to charge mine, although a couple of times I don't think it's fully topped off when using a power bank
What % does it get to?
Better than Garmin's annoying way of it showing 100% charge but it taking another 20-30 mins of charging to really get to 100%. Every Garmin device I've ever had has done it.
My Elemnt Bolt v1 looks to get to full charge, just a no-name usb cable and a multi way wall plug with a couple of USB A sockets in.
I wonder if it's possible for the voltage to be read incorrectly? Or is the battery just booked? My original element gets charged to 100% and it's dropped noticeably by the time I've walked to garage and put it on my bike!
Because it's a Wahoo
I had a Bolt v2 for a while that did something similar, it would report 100% but quickly drop to 95% once you took the plug out.
