Why does my tubeles...
[Closed] Why does my tubeless tyre keep losing pressure?
[#740832]
I have "inherited" one measly tubless tyre (mavic 719 with a Stan's system, I believe) which has been great but suddenly it deflates over a couple of days. I'm pretty sure it's not "burped" and can find no sign of tears, damage, leaks etc on the outside.
Does the gunky stuff lose its mojo after a year or two, or is something else likely to be needing replacing?
I sense this is basic 12 year-old stuff, but tubeless is up there in the "black magic" category for me along with cooking and maths.
Posted : 28/07/2009 8:40 am
i tend to put a couple of capfuls of stans wheel milk (or whatever its called) in each tyre every couple of months as it seems to solidify
Posted : 28/07/2009 8:43 am
Sounds like you need to top up the sealant (or maybe even take the tire off, clean it up and re-seal it).
Posted : 28/07/2009 8:44 am
Gooner - Member
do you clean the old stuff out? if not that will add up quite a lot
Posted : 28/07/2009 8:45 am
Maybe the tyre's not seated properly or got a hole in it that the stan's spooge doesn't seal coz it's gone off.
IMO the Geax stuff stays liquid for longer
What FuzzyWuzzy said ^^
Put an inner in it. Problem solved... 😉
Posted : 28/07/2009 8:48 am
Wow - lots of replies! Thanks guys. As I said, basuic stuff, but I can see I'll be topping it up.
Posted : 28/07/2009 9:09 am
Out of interest did you inflate it with a CO2 canister or just a track pump?
Posted : 28/07/2009 10:43 am
 Solo
Yeah. Where does the dried-out sealant go then ?.
Solo.
Posted : 28/07/2009 10:52 am
A year or two! It dries up in a few months in my experience.
Posted : 28/07/2009 10:56 am
Sorry - away from the pc for a bit. I've been using a trackpump - it goes up OK but is then flat after a day or two.
Posted : 30/07/2009 8:21 am
Which sealant?
Posted : 30/07/2009 9:15 am
