Why does my fecking...
[Closed] Why does my fecking b/b start creaking after Chariot pulling ?!
[#1952504]
Frame is an On-one 456 Ti, bottom bracket is Hope (but have also tried Shimano).
B/b is installed using Finishline Ti prep, b/b threads are de-greased and well cleaned out before installation. Tighten everything up nicely, install chain rings, all ring bolts tight and crank bolt.
I can then ride with no problems, no creaks from the b/b. Happy days...
Then I take the little one out in the Chariot. After a couple of rides of admittedly tugging a bit harder on the cranks the b/b starts creaking. Unhitch the Chariot and the creak remains. The b/b still feels tight, as are all the bolts. From this point on creak only gets worse until it's unbearable.
Nothing to do now except, take out the b/b and go back to step 1 which stops the creak but only until I've been out pulling the Chariot again.
Please help, what am I missing? The noise is definitely from the b/b as after I disassemble/clean/ti-prep it goes away.
Ta for help from anyone.
Posted : 01/09/2010 8:57 pm
 Ogg
a friend had a similar problem - turned out it was the rear quick release being/coming slightly loose not the BB.
Ogg
Posted : 01/09/2010 9:24 pm
Ogg's reasoning sounds more plausible. What QR do you have? I cannot see how, other than the pedalling load being up'ed, the trailer would impact on the BB so much.
Posted : 01/09/2010 9:38 pm
Thanks.
I thought about this after doing some previous searches...
The Chariot has it's own QR which has a socket for the ball joint (which connects the Chariot). It looks like this.
After it starts creaking and I stick my normal Hope QR in, the creak is still there - this is what made me think it wasn't the QR.
I've also tried greasing my QR contact points just in case, which made no difference. Like I said the only way to get rid of the creak was to remove/clean/ti-prep the b/b.
Posted : 01/09/2010 9:50 pm
Try wrapping the threads on the BB cups with PTFE tape before you reinstall them.
Posted : 01/09/2010 9:53 pm
check seatpost clamp, my mates 456ti creaks at this area until he regrease the clamp
Posted : 01/09/2010 10:26 pm
Ta Stu, I did actually try this at one point with some success. Might try it again, maybe in combo with the Ti-prep.
handyman, it's not the seat post clamp, I know this because it's also creaking at the moment - a different type of creak, less repetitive (i.e. not with crank pressure).
I appreciate the suggestions people.
Posted : 01/09/2010 11:01 pm
Stu, I meant to ask - did you meant tape as well as grease (or equivalent) ?
Posted : 02/09/2010 11:26 am
Yep tape first then grease over the top and in the BB shell.
Posted : 02/09/2010 4:20 pm
Cheers Stu - I'll give that a go. Maybe some gypsy spit on top of the grease for good luck!
Posted : 03/09/2010 2:43 pm
Check your BB for coins and sweets, that's whats usually knackered my DVD player after the kids have been near it 🙂
Posted : 03/09/2010 4:17 pm
