Why didn't I d...
[Closed] Why didn't I do this years ago?
[#3959268]
Lock on grips.
Took 2 mins to take the ODIs off the bars instead of faffing about with GT85 and and wooden skewer to remove old grips. Blimey. 😳
Anyone else finally got around to fitting or changing something on the bike that's an obvious improvement but taken ages to get around to doing or is it just me 🙂
Posted : 09/05/2012 8:51 pm
couple of years ago, but chains with power links, so.much.easier.
Posted : 09/05/2012 8:56 pm
Wait until the 2mm hex head rounds off and you have to cut the bloomin thing off!!
For me....it's gears.Although the jury is still out on that one.
Posted : 09/05/2012 9:05 pm
tubeless
tyre on, pump up, ride (once you find a setup that works)
no more faffing with tubes 😛
I went back to normal grips when I saw how much lock ons weigh !
And singlespeed winter bikes.
Posted : 09/05/2012 9:06 pm
Rorschach - Member
Still easier than removing a well-attached slipon tbh.
Inner tubes - tube in, tyre on, pump up and go.
No more faffing about with sealants, compressors, lubes etc.
Posted : 09/05/2012 9:08 pm
Trimix - Member
It'll never catch on you know.
Posted : 09/05/2012 9:17 pm
I'll keep an eye out for rounding the hex then but dont think I'll mind about the extra grams over conventional grips!
Tubeless, there's another thing I might get around too.....
Posted : 09/05/2012 10:17 pm
Foam Lock-ons.
Posted : 09/05/2012 10:28 pm
Uppy-downy seatpost. 1st world solution maybe, but a bloody good one!
slainte 8) rob
Posted : 09/05/2012 10:30 pm
 Haze
Tubeless for me too, never convinced but decided to give it a go when my tyres needing changing.
Very happy with the results so far, though admittedly my old tyres were pretty shot.
Posted : 09/05/2012 11:02 pm
Or hammer a small flat headed screwdriver in the head and undo them.
Posted : 09/05/2012 11:05 pm
troll post? you can't be serious.
Posted : 09/05/2012 11:45 pm
I bet you don't know how much they weigh though?
When you're a SingleTrackAthlete at peak performance, every gram counts mate.
Posted : 09/05/2012 11:50 pm
He did say "saw", not "felt".
Posted : 09/05/2012 11:52 pm
Everything's got split clamps now though - which means lockons are nowhere near as useful as they were 5 years ago. The only real reason to regularly take grips off is to perform maintenance of the bits inboard (shifters/brakes) but now I don't need to bother messing about with the grips.
I'll probably get standard grips next time as they can be a bit thinner (Renthals probably).
Posted : 10/05/2012 12:11 am
My revelation was when I decided having a good dump was as good as rubbish weight saving ideas, anything under 36lb is good enough
Posted : 10/05/2012 2:39 am
[b]thisisnotaspoon - Member[/b]
tubeless
Agreed on all accounts.
Especially the weight of lock ons. I got a few sets of foam grips for £4 a piece, wasn't sure what to think of them but planned to put them on the race bike to save weight.
They saved an incredible amount of weight, are more comfortable and less than half the price. And I can save even more weight by taking the oft mentioned pre ride dump. Double savings.
Posted : 10/05/2012 8:16 am
Weight !
Just to add a small amount of reality a Malteser weighs 2 grams.
Next you will be shaving your legs and riding nude.
Posted : 10/05/2012 8:28 am
