Why did my fork sea...
[Closed] Why did my fork seal detach from my lowers coming down Snowdon?
[#3617559]
Hi guys, coming down snowdon today I heard a pop from my forks and looked down to see I'd lost a load of air pressure and the fork seal on the dual air side was sat at the top of the sanctions.
Forks are rockshox revs u turn teams with the black box. I managed to push the seal back down and pump it back up and worked perfect for the rest of the descent (at a slightly higher pressure as it went pop at 100% travel) Any ideas why this might happen?
Thanks,
Ryan
Posted : 28/01/2012 4:44 pm
Air escaping from the positive spring into the leg. I've had this myself with my Teams, they reinflated fine but popped again later, so ended up needing rebuilt.
Posted : 28/01/2012 4:46 pm
Would a service from tftuned fix this as I was thinking of getting them serviced pretty soonish anyway?
Posted : 28/01/2012 4:48 pm
They'll definately be able to sort it but it might be slightly more involved than a service. Mine had some other internal damage, which may have happened before or during, so needed other parts replaced at the same time- but you might not.
Posted : 28/01/2012 4:53 pm
Thanks for the response, I've sent an email to tf tuned to get an idea of cost 😕
Any other places worth sending the forks or are TF Tuned about the best for rockshox?
Posted : 28/01/2012 5:10 pm
Mine did that.
Fixed under warenty, don't forget they are covered for 2 years...
Posted : 28/01/2012 5:24 pm
 sv
Try Loco Tuning for servicing.
Posted : 28/01/2012 5:47 pm
Because they are Rock Shox
Posted : 28/01/2012 5:50 pm
Cheers, sent Loco an email, £20 cheaper for a service 🙂
Posted : 28/01/2012 5:56 pm
daveagiles - Member
Mine did that.
POSTED 1 HOUR AGO # REPORT-POST
+1. 18Bikes sorted it all out for me
Posted : 28/01/2012 7:11 pm
