Whts the crack with...
[Closed] Whts the crack with rear mech
[#9707857]
Im currently running a 11-42 10sp sunrace cassette and looking to replace the rear mech do i need to get long or medium i see lots of question on crc saying for a 11-42 needing only a medium is this correct
Posted : 07/12/2017 11:35 am
If you are 1x then medium will be fine. Otherwise, long.
Posted : 07/12/2017 11:37 am
Usually the cage only affects the capacity, so if a medium can take at least a 31T difference (42-11), it will work. (l.e. assuming single ring here)
In some cases (road race derailleurs, mostly), the cages also differ in the way the upper pulley is located, affecting the maximum sprocket size that the derailleur supports.
Posted : 07/12/2017 11:38 am
Cage length is basically the determining factor in derailleur capacity. This is the amount of chain it can tension that makes up the difference between the chain length needed for the smallest combination of gears and the largest. Obviously this gets a little more complex with 2x, 3x system but not outrageously.
For a 1x system simply subtract the number of teeth on the smallest cog from the Number on the biggest. This is your tooth difference. Now check the derailleur manufacturer for the ‘capacity’ of the mech you’re looking at. If this is the same or bigger than the tooth difference then all good. If not, you need a longer cage. This is almost a non-issue in 11sp but a genuine consideration in 10sp due to derailleur design.
This isn’t all there is about combining bigger than intended cassettes with derailleurs: there is potential for geometry of the mech to cause fit problems, but no one seems too keen to publish this information when selling cassettes unless they also want to sell things to fix s fit problem.
Posted : 07/12/2017 1:41 pm
