Who's winning the 1...
[Closed] Who's winning the 12 speed OEM war?
Likewise Mark, was good to be there after a long time, shame to not see you. Next year if not before.
Sram will always win the OEM war because they undercut shimano and make it back on the frankly overpriced replacements.
You'd need the OE price lists to say whether they undercut them. I don't think they do. Value varies across parts type between brands but one's not better value overall than the other imo.
Posted : 22/02/2020 8:35 am
Yeah Id not say SRAM was particularly cheap. Also while shimano's line up looks simple on things like brakes and cranks theres a bazillion group variants where brands can move a few quid here and there by speccing versions different to the boxed aftermarket stuff. SRAM on the other hand generally run everything as a branded version with little variants on say a crank, other than the ring you spec on it and its length. That makes it look like SRAMs line up is more complicated, but in fact its probably simpler to figure out what you actually have.
Posted : 22/02/2020 9:01 am
When buying a load of OE kit, is it cheaper to get complete groupsets (perhaps with suspension units too) than to pick and mix?
Posted : 22/02/2020 4:02 pm
Not specifically, or at least not for us, but there is discounts for higher volumes obviously, and if you spend money on shocks and forks as well as drivetrains that volume will build quicker. Its the same as any business really - deals to be had but its not a stitch up/locked in/conspiracy situation, its just normal commercial dealings.
Posted : 22/02/2020 4:23 pm
Interesting, so brands probably could pick & mix more, but I guess it could be seen as a negative by some buyers anyway.
I wonder how Sram are gonna respond to Shimano 12sp, Eagle's been out a while now but I don't believe there's any appetite for 13 speed so perhaps they could make it smoother and less fussy about set-up? And perhaps make the rear mechs less explode-y?
Posted : 22/02/2020 5:12 pm
There are limits to the pick and mix approach. Hope don’t fit SRAM chainsets to their bikes because they want to. SRAM insist on their own chainrings being fitted to bikes using their Eagle kit.
Posted : 22/02/2020 8:08 pm
GX AXS
Posted : 22/02/2020 8:25 pm
GX AXS
I see electronic shifting as a separate market TBH.
They'll need to refresh the mechanical offering at some point and it better be good considering the price and quality of new XT and SLX.
Posted : 23/02/2020 12:40 pm
I know I haven’t used it but it’s difficult to see with 1x that there could be a massive advantage with electronic shifting to justify it costing so much more.
Posted : 23/02/2020 12:43 pm
SRAM havn’t designed UDH for fun, now the hanger has a standard mount and shape they can start designing their drivetrains around this. The hanger doesn’t necessarily have to be a hanger, it could mean the mech bolts directly onto the frame etc.
Posted : 23/02/2020 2:20 pm
so 42t front chainrings and 11-42 cassettes make no sense. For actual cross maybe it does, but then you’re running a 36 or 38t chainring
That's some whopping rations for proper CX racing. I run a 40t front and 11-36t rear on Force CX1. It's not unusual to have the same size front ring with a 11-32 as it's more often than not quicker to run once you get into the big rear cogs.
For context to my earlier post, had my first ride on the new XTR yesterday, proper muddy kind of shit, gears were faultless, brakes were ace, nuff said
Posted : 23/02/2020 2:54 pm
Page 2 / 2
