As above
Thanks in-advance
Any bearing supplier- try ebay, plenty cheap ones. Go for SKF for better quality
where are you based???
Do I need the bearing code/s, plus when I google hope hub bearings nothing clear comes up;-[
I am base in crosshills which is near skipton in west yorkshire
[url= http://www.yell.com/ ][/url] then in the seach for box type "bearing" then in the located in box "your home town or post code"
then pop down there with the bearing and they will replace them they will size them and evry thing £2 each i pay now
there you go mate
Yes, you need the numbers (written on the rubber seals)
Otherwise, take them to a real shop/suppliers and they'll match them.
knock them out then take them to your local bearing supplier
you'll save yourself a fortune
1111
Thanks, thats brilllllllllllll!!!!!!!!!!!!
Thats great everyone,
not a problem at all 😉
