its kind of pro2 shape but a bit smaller and it just has the hope made in the uk logo on it. thanks in advance Tony
Either xc or bulb.
A pic really would help in this instance.
Rusty Mac - Member
Why spoil the fun, does it have disc mounts?
What happens if you put it in a mug of tea?
On a scale of 1 to 10, how much does it hurt if you drop it on your plums from 2 feet up?
Is it a Zaskar? #RetroBike
What's the hub body made of or what colour is te hub body
its an xc, there that's you soted.
If it is a bit smaller than normal maybe it is a Mr Kipling one......
cheers guys im thinking its an xc. i will upload pics later to get a confirmation. Tony
<< sits and waits for the question that usually follows the realisation someone has a XC hub >>
<< sits and wonders what question i should be asking >>
<< wonders what forks / hub interface tony expects to use >>
Is it 20mm/12mm/10mm/15mm compatible.
The answer is no.
Q, how can I convert it to 15/20mm
A, you can't,..
Edit.. Damn my slow typing fingers..
Edit edit. Though If you only need a QR hub it's the best one they've made.. The bearings last forever.
