White Industries Fr...
[Closed] White Industries Freewheels advice
[#3128608]
I've had my WI freewheel just over a year and I have replaced the bearings twice and it has seized up twice.
The last time I just put cheap ebay bearings in. The seals are all in the correct places and I have rebuilt it as instructed by the website.
What I don't want to have to do is remove it and strip it each week and i don't want to pay £20-45 for better bearings each six ,onths as I get better life from a shimano freewheel for less tha £20.
Is this just becaus ei mainly ride at Thetford in the fine silty sand?
Any advice greatfuly recieved.
Posted : 08/09/2011 9:19 pm
i think you have been really unlucky, i have one that i have used for 18 months through the sandy shitty cannock mud as well and i have never changed bearings in it once. the teeth are worn now though
Posted : 08/09/2011 9:21 pm
I thought that they were meant to be bombproof?
Posted : 08/09/2011 9:28 pm
hmmmm I think either you have a duff one or you are a mechanical spanner. 😀
Mine has been bombproof through years of abuse on the chase, peak district and riding at thetty with no issues
Posted : 08/09/2011 9:29 pm
 Keef
they generally last me 3 or 4 years before I have to service 'em,I do a few miles with em an all....
caggyhanded spannermunkey ?
Posted : 08/09/2011 9:34 pm
I gave up on mine and went to a dicta. £14 and i can't tell the difference.
Posted : 08/09/2011 9:39 pm
I had to replace the bearing in mine after about 4 months of commuting. It seized pretty solid. I left the bike there for over a week of no use and it was properly sticky on the first back turn of the cranks. Its just like any bearing if water gets to sit on it for a long time.
Posted : 08/09/2011 9:45 pm
 gazc
had mine a year or so now (3rd hand..) and no problem, a little play in the bearing but i have new one to put in it when i get round to it. commuting/muddy cx riding too. if you're churning through the bearings that quick maybe cheaper in the long run to use shimano etc and treat as disposable?!
Posted : 08/09/2011 11:00 pm
 Keef
I used to get six weeks out of a shitmano,same trails/conditions........
just saying,like..... 😀
Posted : 09/09/2011 10:24 am
Hmm, my WI has been trouble free for years. Bearings replaced once in that time (by Tim at Sideways Cycles actually so I know they were done properly!)
It's lasted far longer than the two Shimano ones I had before the WI. Yours sounds like a duff one or alternatively, you're a crap mechanic. 😉
Posted : 09/09/2011 10:53 am
How tight is your chain tension? If it's too tight you will rip through bearings and pawl springs in record time. Possibly back to being a cackhanded spannermonkey again
Posted : 09/09/2011 11:08 am
Also, like with all sealed bearing components, don't spray GT85/WD40/Any thin lube into the bearing area. It will get past the seals and will disolve what little grease there is and cut bearing life very short.
Posted : 09/09/2011 11:13 am
tazzymtb - Member
I am alright on the spanners. I worked spannering for a couple of shops and I do everything myself. Nothing normally causes me an issue.
Although I think it maybe as Tazzy says and it maybe my chain tension destroying them.
Posted : 09/09/2011 12:53 pm
had one on mine for two years( it was 2nd hand then) and never touched it. only changed it go up a gear . the one that has been took off stripped and look perfect inside so if any body wants a 19t let me know 🙂
Posted : 09/09/2011 1:31 pm
 Keef
my pal may be interested in the 19 Sofa......
how much,and are you going SSuk next week ?
Posted : 09/09/2011 4:09 pm
Hi Keith , how about £35, its in good nick, teeth look good still etc.
will be at ssuk
will chuck it in the van incase
Posted : 09/09/2011 4:41 pm
Hi Matt,
If Keith's mate doesn't take it I probably will. Starting to struggle with my 17 and thinking of going to an 18 - might just go to 1 19 and be done for a few more years slowing down:-)
Will be at SSUK abw.
Kev
Posted : 09/09/2011 4:48 pm
Hi Kev. ok your 2nd.
form an orderly cue behind Keiths mate
see you next weekend for more tediousbikeshenanigans
Posted : 09/09/2011 4:50 pm
 Keef
sounds good Matt,I'm game for cog related antics nxt wknd he'll be coming down with us Chase posse,for his first ever SS event and ride,and yes he's a different 'virgin' from Ireland !
Posted : 09/09/2011 5:36 pm
see you next week then 😛
you chase lot much have very good grooming tactics to keep picking up virgins to bring to events
Posted : 09/09/2011 7:17 pm
I've got 3 virgins wiv me an all from the cannocky area.
Posted : 09/09/2011 7:33 pm
 Keef
LOL,ooh yes,we have !
Posted : 09/09/2011 8:19 pm
keef adopting the cannock singlespeeders "come hither stance" whilst wearing tweed and getting ready to throw a virgin into the back of the pikey wagon
Posted : 09/09/2011 8:24 pm
 Keef
oh Taz,you've been spying on me.........
again.
Posted : 09/09/2011 8:27 pm
I think if you submerge the freewheel they then die shortly afterwards.
Or, at least, that's been my experience.
I don't think waterproof sealed bearings exist that will also be lightweight and cheap.
As it happens, I need to replace the 6808 bearing in my WI freewheel...
Posted : 09/09/2011 8:39 pm
