I have a pair of White Brothes fluid 120's... bought them as ex-demo's, ridden once, stuck them on my rig and they look great.... for some reason when i drop down kerbs they knock, if you smack front wheel off the floor, using travel they knock bad and i can feel it through bars... Headset tight, 20mm axle tight. Any thoughts or anyone know somewhere in uk that would look at them? Cheers all
Posted : 20/12/2011 11:57 pm
they may run on the same system as my Loops. basically the lockout/compression adjustment works from a magnet type deal. the slight knock is the magnet disangaging for a split second.
this is what I was told about mine
Matt
Posted : 21/12/2011 12:31 am
