While we wait for t...
[Closed] While we wait for the Cotic Rocket...
I believe there was 50 of the first batch of UK ones. Exclusive!
Posted : 24/06/2014 1:36 pm
So, once the UK manufacturing is sorted has Cy mentioned anything about painting them with more than 2 colour choices? I say more but I can only ride black frames, with black on black [i]muyda colorway[/i].
Posted : 25/06/2014 10:45 am
So, once the UK manufacturing is sorted has Cy mentioned anything about painting them with more than 2 colour choices? I say more but I can only ride black frames, with black on black muyda colorway.
http://www.cotic.co.uk/product/rocket ,the colours are there looks like 4
Posted : 26/06/2014 9:19 am
What's the buzz on the 29er version, anyone?
Posted : 26/06/2014 9:40 am
The prototype 29er versions won masters cat and 16th in Elites at Afan UKGE but I'm guessing that's all they are for now - prototypes, until the next batch of 26ers are out
Posted : 26/06/2014 9:59 am
Last advice was that there are plans for a 29er but they're concentrating on getting the first 50 26ers out first.
On the 26ers... the black or white options for the rear 'triangle' are apparently for people to match with their fork colour. Also, there are design/manufacture changes to the shock linkage and mounting that will improve shock performance, save about 100 grams, and will enable use of a stealth dropper.
Posted : 26/06/2014 10:06 am
Are all forks black and white these days?
Posted : 26/06/2014 11:03 am
Yeah that's what made me think of them, looks like it could be a real contender in the AM 29er category (I won't use the E word).
Nice to see a company doing things thoroughly and properly (if a bit slowly).
Posted : 26/06/2014 11:15 am
oooh that green and black!
Pretty sure those colours weren't up yesterday or maybe it was just the selection under 'check availability'
Posted : 26/06/2014 12:29 pm
That new product page went up yesterday, to coincide with Cy telling people who have pre-ordered UK frames about their options.
The black rear option came about because the team were using “murdered out” Pikes on Taiwaan frames with white rears, and it seemed pretty obvious that they would look better with matching black rears. So that option is available for those patient people who've ordered and already know what forks they're planning on fitting.
Oh, black rears also come with black downtube panels, as the mockups suggest.
Posted : 26/06/2014 12:36 pm
Just done some photoshop work and I think they look better with white panels and white forks, but white is harder to clean. hmmmm.
Posted : 26/06/2014 12:53 pm
But white Pikes look appalling with the black stanchions!
Other brands are available of course.
Posted : 26/06/2014 12:55 pm
White Slants; wet wipes and small children for the cleaning - problem solved.
Posted : 26/06/2014 12:59 pm
Strike that - the panels have gone. It looks like the whole rear triangle is now single-colour.
Not a fan. Don't like this years Transition Coverts for the same reason.
Posted : 26/06/2014 1:05 pm
not with the black and white rocket frame they don't 8)
oh I'm so happy to hear I'm not the only one 😳
Posted : 26/06/2014 1:08 pm
Posted : 26/06/2014 2:09 pm
I was chatting with one of the guys riding the 29 Rocket at UKGE at the weekend. I'm not sure if its been mentioned before (havent read all the thread), but he told me that they were being built with steel swingarms now? He might be talking about the 29 only, but would be worth investigating if you were buying. Site still says 7005 swingarm...
Posted : 26/06/2014 2:15 pm
Rockets came in black and white in the 2012 batch.
Steel swingarm hasn't been mentioned before.
Posted : 26/06/2014 2:34 pm
what difference would it make, it says its steel in the whats new section
Posted : 26/06/2014 3:10 pm
I'd missed that 'what's new' section:
The Rocket is now a made in the UK!
There are many detail improvements to the Rocket now we have full control of the manufacturing.
The most obvious change is the move to the horseshoe shock actuation. This gives better control over the spring rate deep in the travel and reduces the stress in the seatstay tubes at bottom out.
The latest Rocket also features our new Torque Box swingarm. A hollow shell steel head reduces weight over CNC aluminium parts and allows a far bigger cross brace, which improves torsional stiffness. Butted Reynolds 631 chainstays are stiffer laterally than the aluminium stays they replace for the same weight. Finally, the dropouts are now a steel/aluminium bonded hybrid construction which uses both materials to their best advantage.
Front triangles now feature routing for internal dropper seatposts just below the droplink mounting. To compliment this the external top tube routing for dropper seatposts is now bolt on P-clips for a cleaner look if you do have a Stealth post.
Now available in "that green" as well as the signature Cotic orange colour, and with a choice of black or white rear and panel, so that you can match the frame to your fork colour, or favourite jersey for that matter.
Posted : 26/06/2014 3:29 pm
They need to update the frame spec section then:
Reynolds 853 Ovalform and DZB tubed front end brings precision, durability and strength
44mm standard head tube designed with external bottom cup for taper steerer compatiblity and zero stack top cup for minimal stack height
Oversized 35mm seat tube for super stiff support for the main suspension pivots
31.6mm seatpost size is dropper seatpost compatible and the frame has hose clips for the remote under the top tube
ISCG05 mounts on regular threaded bottom bracket bring drivetrain security and reliability
[b]Asymmetric 7005-T6 aluminium swingarm with Syntace X-12 142 x 12 rear axle[/b]
15mm pivots for BB and droplink keep the frame solid front to rear
Clearance for big tyres - 2.5" DH tyres run with plenty of clearance
Geometry for speed, fun and interaction using 140, 150 or 160mm forks. 66.5deg head angle and low 13.3" BB with 150mm fork
150mm of Cotic droplink suspension brings precision, fun and interaction via a strong progression rate on the linkage driven single pivot layout
Sizes - 16", 17.5", 19". The frames are designed to be compact and chuckable.
Weight - 7.6lbs for the 16" including Fox Float RL shock
As for difference, I dont know, but weight will almost certainly be affected.
Posted : 26/06/2014 3:40 pm
The frame will be around 100g lighter.
Posted : 26/06/2014 3:49 pm
Did you read the above. It mentions weight twice. Once to say a component is lighter and another is the same.
So overall, I imagine it will be unaffected.
Bonded dropouts sound scary though despite flying in bonded aeroplanes, etc, etc, etc.
Edit: beaten to it with an actual weight - 100g. Well done to them.
Posted : 26/06/2014 3:51 pm
bonded aeroplanes thus below
http://www.britmodeller.com/forums/index.php?/topic/65611-54-sqn-rotol-spitfire-i-march-1940-148/
Posted : 26/06/2014 4:32 pm
Is this a pic of it?
[img] ?1295151198[/img]
Posted : 26/06/2014 5:11 pm
Is this a 2014 or 2015 bike, I'm drawjopped there's no 650b as tbh if I was looking that's where I would be going
Posted : 26/06/2014 6:25 pm
drawjopped
I'm drawjopped too, quite frankly....
Posted : 26/06/2014 6:31 pm
Seriously the textaphone predictive text auto-corrected , I like it though.
Posted : 26/06/2014 6:37 pm
Do you ever get the feeling Cy designed the Rocket purely to troll internet forums? LOL steel are teh heavies!
Posted : 26/06/2014 7:50 pm
So what's the feeling on the new alu shock actuator thingermejig? I really liked the sweeping steel bars. They seemed different. I'd like to see them on a built frame.
Posted : 27/06/2014 11:59 am
@ chakaping - I was going for this look
Posted : 27/06/2014 12:21 pm
?? It has kind of piqued my interest in uprating from my giant
Posted : 27/06/2014 7:44 pm
Odd question.
The shocks on the rocket are they just standard tune shocks or is it specific to the rocket? I.e. if i bought the frame only option and got a tftuned version of it which includes
Price includes set-up and heavy-duty mount kits to suit you and your bike, as well as free shipping (mainland UK).
is that worth doing?
looked at the Cane creek but i think i'd prefer fit and forget! rather than knobs to twiddle
Posted : 29/06/2014 10:32 pm
There is a base tune for the CCDBA CS on the Cane Creek site that was worked out by Cy, I think. Last time I looked it matched the tune settings he sent me when I asked back in February. Interestingly, there is a different base tune for the Rocket for the new CCDBA Inline - I don't know where that's come from given that the shock isn't available yet and Cotic haven't mentioned the Inline as a possible option.
You could just set the base tune and forget it until you feel like experimenting a bit. The Cane Creek field guide looks useful for people not used to tuning their own shocks (like me).
There is an internal setting (i.e. not user-adjustable) that sets how much effect the Climb Switch has. Again, according to Cy, the shocks supplied by Cotic will have this set specifically for the Rocket - I think Cy found the setting on the shock he was sent to test to be too soft, so it should be set a bit firmer than default. The CS just adds a set amount of low speed compression and rebound to the tune the user sets him/herself.
Posted : 30/06/2014 9:32 am
Any news on the rockit?
Colours ? (Cy, needs to be black on black)
Posted : 21/07/2014 3:34 pm
scruff - Member
A Rocket, earlier (not my photo, but it's in the public domain so I guess it's OK).
EDIT. Image removed just in case.
Posted : 21/07/2014 8:18 pm
Rare as hens teeth
Posted : 21/07/2014 9:10 pm
Have now seen a photo of a UK built front triangle - not sure if it's been welded up or still dry-fitting to get the jigs set up, but seems things are on the move.
Posted : 22/07/2014 2:05 pm
Be nice to get a ball park delivery weeks or months rather than it be completely open ended .....
Posted : 22/07/2014 5:05 pm
Last news from Cy suggested 6 weeks-ish from the end of June.
Much as I'm hopeful, I'm not holding my breath.
Posted : 22/07/2014 9:27 pm
Failure to launch,from what I seen so far no pat on the back or high fives
Posted : 23/07/2014 8:28 am
how is this farce not killing cotic?
Posted : 23/07/2014 8:37 am
I think, that once released, they should give heavily discounted frames to anyone that has posted on this thread! 😀
Posted : 23/07/2014 8:47 am
jam bo - Member
I think just because their core business is really damn good hardtails and that's been unaffected. Also most folks probably realise they're having trouble because they're trying to do something that's hard enough that nobody else in the industry has even tried.
Obviously I can be laid back because I'm not waiting for a Rocket 🙂
Posted : 23/07/2014 9:18 am
Except Orange Brompton and Pashley to name 3 who have been making things for years.
Posted : 23/07/2014 10:25 am
Page 3 / 4
