I've a budget of £600 and have to buy from Halfords (due to our cycle to work scheme)
I was set on the 2013\14 Bizango due to positive reviews etc but the 2015 model has just come out...
The 2015 Bizango is quite a different bike but no independent reviews yet.
Do I go new, old or other?
Other than the kink in the top tube the frame looks the same as my 2014 version. If they haven't messed with the angles i'd drop my cash on the new one, think I'd prefer the 20 speed gearing on the the new one 😕
The new one isnt as pretty, but had better kit, up to you.
Other stores accept Halfords cycle to work vouchers so you don't HAVE to go to them ( i didn't ) .
True but you're not likely to find anything else for £600 that competes.
I love mine - but the new one still has a 1 1/8th headtube!!? Which makes upgrading the fork a ball ache.
The new one is a kg lighter!
DOnt get one of the ones off ebay with no dropouts
Kraftyone - Surely they have kept a 44mm headtube like the 2014 one?
I've ordered the 2015 one - should pick it up on Friday!
Hope its the right choice - take the point re weight, bit nervous re gearing at top ratio is only 3.6:1
headset says 1/18th semi integrated which is 44mm? so you can fit a tapered fork with the right lower cup
