which tubeless conv...
[Closed] which tubeless conversion kit
[#7254209]
I have a Giant Reign 650b and looking to go tubeless.... there are a load of different options out there with Stans being more expensive..... any advice on which kit etc thanks
Posted : 08/08/2015 5:36 pm
A lot would depend on your wheels. Most these days can be tubeless'd with some tape and tubeless valves. You don't necessarily need the proper rim strips/valves you get in the expensive kits.
Posted : 08/08/2015 6:03 pm
Superstar brass valves and tape come out pretty cheap and work good.
One roll is enough for two wraps on each wheel, which I find gives a more reliable seal.
Posted : 08/08/2015 6:11 pm
cheers - will give them a look see. thanks
Posted : 08/08/2015 10:19 pm
I use Doc Blue from my LBS - made by Stans but way cheaper!! Bontrager juice was rubbish.
Posted : 08/08/2015 10:24 pm
I prefer Gorilla Tape rather than Superstar tape. It is another option at least.
Posted : 08/08/2015 10:26 pm
http://www.pinkbike.com/news/Tech-Tuesday-Gorilla-Tape-Tubeless-Conversion.html
You don't have to use Gorrilla brand. Just any heavy duty tape. I used unbranded Heavy Duty Duct Tape. Worked perfectly.
Stans sealant however is essential. Maybe another brand, but Stans works great. Use lots. Two or three scoops per tyre. Half the problems people get is lack of sealant.
Posted : 09/08/2015 12:42 am
I'm using joes rims strips and they work very well
Posted : 09/08/2015 7:00 am
Not used rim straps in years, tape and decent tyres are the most important bits, along with removable core valves if you need faster inflation to get them seated.
Posted : 09/08/2015 7:10 am
