Which sport am I un...
[Closed] Which sport am I under performing in - Run or Bike?
[#7287665]
I appreciate there's so many variables here and I'm not even sure what question I'm asking.
When I run my heart rate is consistently very high e.g. marathon was run in 4 hours at about 85% max hr although felt pretty comfortable.
Cycling I seem to average about 70% max over a decent ride and its only big hills I get anywhere near max.
For people who are good at both sports; is this variation normal or should averages be much closer between them.
Could this indicate my running technique is poor and I should be running faster times, or am I not pushing hard enough on the bike and should be quicker?
Posted : 24/08/2015 9:43 pm
Running is hard. Expect if you went out running 3 times a week things might change?
Posted : 24/08/2015 9:56 pm
My HR is generally higher running than cycling.
So you are probably not far off "normal".
Posted : 24/08/2015 9:58 pm
You need to do an 'on bike max HR' test to get an accurate figure.
Mine is 189 bike 196 run
Posted : 24/08/2015 10:00 pm
You have different max HR for different sports. A lot of it is to do with whether your body weight is supported (eg cycling) or not (eg running).
Posted : 24/08/2015 10:02 pm
