I've got a set of Hope Hoops with Stans Flows rims on order, and am a bit confused about which rim tape I should be using. If I understand it right, all Hope Hoops just come with the standard cloth-like rim tape? But I've read that there's an alternative tape for Stans Flows that is lighter and will allow easier upgrade to a tubeless set up later on.
I don't intend going tubeless right away, but may do once the current tyres bite the dust (sorry) 🙂
So what rim strips should I be going for?
Many thanks in advance.
25mm yellow Stans tape for Flow rims.
[url= http://www.justridingalong.com/shop.php?product=47&r=y5e4 ]http://www.justridingalong.com/shop.php?product=47&r=y5e4[/url]
25mm Stans yellow tape is the standard stuff. People have tried other options though.
Thanks for the link - seems simple enough!
Kevin dead simple. You can ru your current tyres tubeless.
Can I? Aren't there issues with the stans slime causing some tyres to degrade/melt or something? I have Maxxis Minions if that's of any relevance...
kevin1911 - Member
XC bike - Running single ply Minions tubless on Flows with Stans. solution no problems.
Big bike - Minions duel ply on Flows again no problems.
