Which replacement j...
[Closed] Which replacement jockey wheels for Sram X9
[#1150312]
Haven't seen a thread on this for a while and it's time to replace the jockey wheels on at least one of my mechs.
So which ones are you all using?
IIRC it's the top wheel that has a unique offset, so are there any cheapish ones I can buy for the bottom wheel?
Had Tacx replacement ones before but seemed a bit pricey at about £16.
Posted : 22/12/2009 1:26 pm
If you file the locating tab off the mech cage you can use a normal jockey wheel, the wheel itself will sit a few mm lower but shifting seems fine.
Posted : 22/12/2009 2:03 pm
KCNC Jockey Wheels
http://www.readytoridecycles.co.uk/?gclid=CK_08K2X6p4CFQZBlAodb3j9LA
Not cheap, but so far have put up with everything the winter has thrown at them.
Posted : 22/12/2009 2:49 pm
Have KCNC started making jockey wheels that fit X9?
Posted : 22/12/2009 2:58 pm
If you do what I said then yes they will fit, that's what I'm using.
Posted : 22/12/2009 4:14 pm
Nobody use any jockey wheels that cost less than £30 then?
Thanks for the filing tip though schrickvr6, will have a look at that.
Posted : 22/12/2009 6:10 pm
You can get a pair of KCNC wheels on the bay of e for £16-17 delivered...
Posted : 22/12/2009 6:17 pm
They fit XO fine.
Posted : 23/12/2009 1:28 am
X0 & X9 have different jockey wheels, so the KCNC X0 jockey wheels will not fit X9
Posted : 23/12/2009 8:16 am
Cheers schrick
I might try that on one of my bikes, it can be hard work finding anyone with the correct jockey wheels for X9.
Remember asking for some in a local shop and was given some which he claimed would fit, had to go an attempt to put them on before he believed me that they would not fit.
Posted : 23/12/2009 10:53 am
