Which replacement c...
[Closed] Which replacement crankset for a Brompton?
[#5662486]
The chainring on my S3 is hammered, and I need to change it out. Unfortunately, it's the one piece cranks and chainring. Can I whack an Alfine chainset on? What do people use, and what would you recommend? I'm doing about 85 miles a week to and from work, and I'd rather get something with a chainring I can flip and replace.
Posted : 04/11/2013 5:11 pm
Ben Cooper will be your expert. but I'm pretty sure you can run any road crank of your choice.
A quick google image search for "brompton crankset" shows all manner of ideas including Zipp carbons and what looks suspiciously like middleburns.
(2013 brommie cranks do have interchangeable rings)
Posted : 04/11/2013 5:30 pm
Ta chap. It does look like there's oodles of clearance there, but I wasn't sure about chainline and all that jazz.
Maybe I won't go for the Zipps after ordering the Udderlet's Cnoc 14 just now.
Posted : 04/11/2013 5:34 pm
Most chainsets with the ring in the middle position are okay - just make sure you have enough clearance between the chainring or spider and the rear frame at the pivot.
Also, if you've got the folding pedal, you want a crankset which doesn't have too much metal around the pedal hole on the left side. Or you can cut away the spare metal if you have to - that's what I do with 33t chainsets for my 8-Spd kits.
Posted : 04/11/2013 5:37 pm
Thanks, Ben!
I'm using SPDs, so great advice.
Annoyingly, I have a couple of spare pairs of MTB cranks, but not road cranks. Grr.
Posted : 04/11/2013 10:08 pm
The originals are still available and pretty light.
RSXs fitted OK on mine also, just about.
Posted : 04/11/2013 10:10 pm
[url= http://www.bikeforums.net/archive/index.php/t-809974.html ]Bob's yer Uncle...[/url]
Posted : 05/11/2013 12:31 am
Thanks all. Looks like I should have asked a bit earlier! Riding in to work on Tuesday, a heard / felt one of the pawls snap in the hub (I've done this before) and lost the lowest gear as a result. No problem - my shop has a few spares and the nouse to tinker with those hubs. Then, on the way back, I stood on the pedals to accelerate away from the lights - and went over the bars. Nothing hurt but my pride, but the drivetrain definitely needs replacing - the teeth are beyond worn and the chain beyond stretched. I have a spare chain and a replacement sprocket, now I just need the chainset... I've been scouring eBay, and will let you know how I get on.
Posted : 08/11/2013 3:06 pm
