Which Orange 650b? ...
[Closed] Which Orange 650b? Alpine or 5pro
Ecky- that's kinda what I was meaning back on page 1, but was assured I was wrong (which having owned/ridden several single-pivot Orange bikes was confusing slightly).
The 'locking/skipping' bit does happen, or at least is much more noticeable on a single-pivot IME.
Posted : 31/10/2014 11:28 am
I think the problem comes with using the term brake-jack as there are those who will will argue that can't happen and I suspect that they are technically correct. However, it may still be the case that Orange bikes handle more poorly with the back brake on than other designs. I don't know.
Posted : 31/10/2014 11:38 am
My Oranges do skip a bit when braking over bumps, but I can't see how the number of pivots make a difference UNLESS the single pivot design requires you to run more rebound damping or platform damping...
Posted : 31/10/2014 11:53 am
You could be onto something. My Five tends to live in trail mode. Looking at all those anti-squat numbers though I think I might start playing with leaving the rear shock fully open for a bit.
Posted : 31/10/2014 12:04 pm
I almost always have it open (RP23) unless it's a long fireroad climb, or road. When I hit the trails I put the propedal on setting 1 and then use the switch - rarely.
My Patriot has the Manitou Swinger x4 with the air chamber for SPV. I used to run it with the minimum pressure, but since I moved the pivot I thought I'd up the pressure to give more support, but this also comes with more platform. It's definitely made it skippier on rough stuff so I think I will put it back next time.
The Patriot wants a CCDB to be fair, but then again I want £400 🙂
Posted : 31/10/2014 12:20 pm
The bike was much, much better on the trails Sunday, didnt do San Marino, but it popped much easier, felt planted in the corners and no punctures (sometimes 3 a ride, with slime tubes too). Ended putting in 250psi in the rear (up from 200) and 20-30psi in the front, cant remember the pressure... both sets are travelling 75% of the stanchion on a regular ride. Thanks for the advice!!
As for the Orange Five, if I can get this 2014 for £2800 I think I'm in, but chakaping if I can build one up for the same cash youve got me thinking!! Will need to do some shopping this eve.... 😉
thanks again guys!
Posted : 03/11/2014 9:26 am
I think the skipping comes from breaking when the shock is compressed, Chain locks out.. When you come off the break the rear end is still compressed under Chain lock. Hit a bump with the shock somewhat compressed and it doesn't absorb the bump well as the shock wants to decompress and results in skipping..
That's atleast how I've come to analyse it on my 5..
Posted : 03/11/2014 10:05 am
Ive got my eye on a 2014 Five Pro which is 3 months old, the guy wants £2800 for it which feels like a deal?
You can get brand new 2014 Pro's for less then that so not a good deal.
Pro here for £2399.
http://www.drakescycles.co.uk/m1b114s377p4304/ORANGE_Five_Pro_2014
Or a 5 29 (Alpine 5) for even less.
http://www.drakescycles.co.uk/m1b114s361p4463/ORANGE_Five_29_Pro_Custom_Colours_2014
Posted : 03/11/2014 12:45 pm
I've got a '14 Five with a Pike and a CCDB air. It's a fantastic bike. The shock makes all the difference. I think it feels like a much bigger bike, a bit like my '11 Enduro that had 160mm f&r, but pedals really well. I'd be tempted to go down a class in spec and then upgrade fork and shock to something better.
Frame, fork, shock and wheels are the most important component (IMHO).
Posted : 03/11/2014 12:53 pm
£2.8k is well over the odds for 2ndhand yeah.
As I said before, you'll really want that frame warranty too.
Posted : 03/11/2014 1:06 pm
Best bet is to build one yourself..IMHO
My 5 build cost me £3340.
Pike
CCDB CS
XT Groupset
Stan's flows hope pro 2's
Reverb
Posted : 03/11/2014 2:44 pm
I have a 2011 5 and I bloody love it. I bought the bike ex-demo and over years pretty much everything has been replaced except cranks, shock and front 1/2 of frame. 🙂 ....even the paint is new.
I had some good use & re-use out of the original parts though.
I think most people have covered the other topics here already. Enjoy.
...p.s. I've always thought chakaping had 5-envy. Now I can see the amount of research he's put into this. I know it 😉
Posted : 03/11/2014 7:26 pm
Just bought a 2014 Five Pro, CTD kashi shock and CTD Fox 34 kashi forks. Its a 1 x10. Ex-demo, clean as and comes with 5yr frame warranty, 2yr paint and 1yr parts - £2250 inc delivery - so happy as Larry could be!
Thanks for the advice guys.
Rob
Posted : 11/11/2014 8:49 am
Page 2 / 2
