so considering getting some older (2005 onwards) 100mm forks, but I need to be looking for post mount (post mount 160mm mono mini issues)
anyone suggest any gooduns?
light but strong, ideally with v mounts and disk tabs
also do any carbon rigid forks come with post mounts?
Manitou
You can get adapters for post mount calipers and IS fork mounts for 160mm rotors. They're pretty common
really i thought they all upped the rotor size by 20mm?
if i can get a post to is adapter which doesnt up the rotor size for a hope mono mini 2006 i would be well chuffed!!!!!
Yup, Manitou did post mount from way back.
Don't Hope do different side bodies to take account of post/IS mounts and disc sizes? You can certainly get a plain adapter if not.
Nope.
Post mount fork and IS caliper requires +20mm in rotor size.
IS mount fork and post mount caliper just requires the right mount.
If its a [u]mono[/u] mini, you can't get a half caliper. Plus if it is a number 2 {?} 160mm front IS caliper, you can't postmount it without using the +20mm IS to post mount.
If it is a number 2 160mm front post caliper, you just need a port to post mount, if it dosn't go on direct.
thats pretty cool!
thinking about i did have all the probs with an is hope caliper, had to change it.
nice one chaps
oh the roller coaster of emotions.....
they are 2006/7 mono minis, black and gold ones
front is post mount, and fits straight onto my fox forks using 160mm rotors
So your caliper looks like this?
If so you can use an IS mount fork and one of these:
http://www.chainreactioncycles.com/Models.aspx?ModelID=13732
It really is that simple.
cheers !
