Which Loctite do I ...
[Closed] Which Loctite do I need...?
[#5348147]
To fix a loose headset into a headtube? Headtube is a little big and I dont want to shim it.
Or is there another adhesive people recommend?
Posted : 19/07/2013 6:48 pm
660 is a good gap filler
*EDIT - I promise I didn't just read that from above, just what I've used at work*
Posted : 19/07/2013 7:14 pm
Cheers.
Posted : 19/07/2013 7:31 pm
Motivforz - yeah right we believe you 😉
Posted : 19/07/2013 9:10 pm
 J273
Without me starting another thread (Hope the OP dont mind?)
What loctite would i need for frame bearing pivot (Dropout) bolts ?
Posted : 19/07/2013 10:33 pm
be careful with things like 638 and 648 - ideal for setting liners into cyclinder blocks but are designed for items that are not expected to come apart...
for the DIY/home uers then (641) is ideal, the easy to get 'stud bearing fit' #270 which is sold in little tubes in halford etc is not so good as it not ideal for bigger gaps... but if your stuck worth a try..
as with all for instructions and leave assembled parts to properly cure before usinge tc
Posted : 19/07/2013 10:49 pm
