Which light seatpos...
[Closed] Which light seatpost?
[#6665027]
I was going with one of these:
http://www.xcracer.com/shop/viewproduct.php?productid=109
...but at 75kg in my b'day suit, I'd rather go with something a bit less fragile.
Any suggestions? I have a 400mm Thompson Elite, at 271g so would like to lose a bit of weight off that - is bad/dangerous to suggest I saw 50mm off of it, as this would still leave 120mm in the frame?
No "go for a dump comments please", thats a given.
Posted : 27/11/2014 10:39 am
What diameter do you need? Currently running kore t-rail saddle seatpost combo and its pretty light. Tricky to find carbon version but CRC had so me of the alloy ones left.
Posted : 27/11/2014 10:44 am
120mm in the frame sounds like plenty. As long as it goes a good bit below any joins (top tube and seat stays) then it should be fine.
Posted : 27/11/2014 10:46 am
I have a thomson masterpiece 30.9 for sale… £70 🙂
New bike has a different size otherwise would keep haha
Posted : 27/11/2014 10:49 am
Ritchey have always been a good bet for posts in the light and strong category.
Posted : 27/11/2014 10:50 am
I need 30.9.
The seatpost would be 50mm below the TT join. So no issues cutting it down then, which sounds like the cheapest way to go about it...
Posted : 27/11/2014 10:51 am
That would be fine IMO.
Posted : 27/11/2014 10:52 am
What type of riding?
The Carbon Cycles seat post is light and cheap: http://www.carboncycles.cc/?product_code=CC-S0935
Note, they only recommend it for XC riding a max rider weight of around 90kg.
Or if you don't mind getting a new saddle too, I've regularly seen SDG I beam stuff going very cheap on CRC. It was a few years back but I picked up their carbon seat post and a Bel Air saddle for around £80 total and together I think they weighted 450g all together. I think that's a pretty good weight for something rated for all mountain riding? I emailed them to confirm and they were happy with me doing aggressive riding on it.
Posted : 27/11/2014 12:07 pm
I have the KCNC posts on ll my bikes. I'm around 73kg at the mo but have been quite a bit more without bending one.
Plenty of cheaper KCNC posts on eBay.
Posted : 27/11/2014 12:19 pm
I have USE alien ali posts on 2 of mine. I'm 70kg and although they are a right faff to sort they are very light (254g) 350mm 31.6. Not had any probs even on my 'bigger' bike. I have a carbon i beam as a spare one which is heavier.
Posted : 27/11/2014 12:33 pm
I got more enthusiastic, seatpost is now only 50mm below the bottom of the TT join - I'm guessing this is OK?
But as a result my now mini-thompson is 201g, and has a nice shiny mini-chamfer at the bottom courtesy of a wet&dry finish.
A nice little 15 min lunch hour project.
Posted : 27/11/2014 2:15 pm
Oh, I've just read about Anthems and cracked top tubes and a recall. Appreciate this was in 2011 but its made me nervous...
Posted : 27/11/2014 2:34 pm
That's not light...
Stop fannying around and buy the KCNC, sell the (now significantly shorter) Thomson to offset cost!
Posted : 27/11/2014 2:38 pm
Cost isn't the issue. Its the KCNC potentially snapping. Then again, I'm not the "hardest" or "clumsiest" rider around and I do "float" when riding...
njee while I have your attention - I just replaced the wheelset to AC MTB race, quaxar's & Ron/Beaver with a 810g loss in weight over OEM 🙂
Posted : 27/11/2014 2:47 pm
And you're more than 10% under the weight limit.
Very good on the wheels, gold star.
Posted : 27/11/2014 2:49 pm
Yes, that'll show that Nobby....
I'm worried I won't be with kit on. Remember this is the "one" bike now, so it needs to accomodate an "everday" kit weight with water etc as well as a "race" kit weight which would be lighter.
Actually buying the 400mm KCNC might help, its still 100g lighter but there'd be much more in the frame...
Posted : 27/11/2014 2:53 pm
If you are worried about the weight limit, get this KCNC, then...
http://www.xcracer.com/shop/viewproduct.php?productid=319
I've got one on my FSR and it is fine - few years old now and it's still straight - I'm around 74kg in my birthday suit. Bit heavier than the scandium one, but still light and has a much higher weight limit. The clamp is great too.
They do it in 400mm as well.
Cutting the seatpost down seems like a bit of a rash move. Would you not have been better off sticking it on ebay to offset the cost of a new post, rather than hack a load off it?
Posted : 27/11/2014 2:56 pm
@stumpy...
I'm on a large Anthem 29, which really is quite large in the TT, 18mm layback would probably be an issue. My current in-line has the saddle cetral I guess...
Posted : 27/11/2014 2:58 pm
The 1990's would also like to check if you've -
trimmed your bars to be shoulder width
fitted foam grips
trimmed your brake and gear cables as short as possible so you can't turn more than 45 degrees
fitted air-B latex inner tubes
running 28 spokes on the front
fitted Ritchey 'Z' max 1.7" tyres (red front, black rear natch)
drilled holes in your cranks
fitted some flimsy aftermarket QRs
ditched the seat QR
replaced your mech hangar bolt with an aluminium one (and removed at least some of the skin from your knuckles) then zip tied it on
Can't think of anymore that used to be in the 'Top 10 ways to save weight' yearly articles in the MTB mags of the day.
Posted : 27/11/2014 3:04 pm
You won't carry 10kg of weight. Even with the sort of shit most on here advocate carrying for 3 miles around a trail centre! Look at the weight limit for road use too, can't see it being hugely fragile. I may still have a brand new New Ultimate carbon one alternatively, forget what sizes I've got. They're light. My 27.2 is 123g.
Posted : 27/11/2014 3:09 pm
Weight limit for XC is 85kg, you said you're 75Kg, how much kit do you wear?!
Being that it has a 120Kg limit for road use that implies it's mor than capable of handling you sat on it, the difference is to account for banging into things off road while sat down, and hopefully you're not sat down when you bang into things?
Based on above assume the weight limit is a bit conservative too then I'm sure you'll be fine.
Posted : 27/11/2014 3:10 pm
Here's an interesting point;
The OEM seatpost (giant connect SL) if set at the minimum insertion mark would only extend 20mm beyond/under the TT junction. I didn't come with a warning no to do that and therefore...
Having my now 300mm Thomson extending 50mm below the TT junction would seem perfectly safe.
hmm, NJEE/Amedias, I see that. I'm not a kit abusing, thrasing, clumsy rider so I guess you have a point.
And my wife has just left the house *wanders off to XC Racer* 😀
Posted : 27/11/2014 3:12 pm
Meant to add that the New Ultimate ones have a 90kg weight limit.
Posted : 27/11/2014 3:13 pm
Kryton57 - Member
@stumpy...
The answer is obviously a smaller frame (which will save you even more weight.... 😆
Posted : 27/11/2014 3:14 pm
Just weighed my USE Alien...dont know where I came up with 254g....^ njee its 174grammes 31.6 350mm
Posted : 27/11/2014 3:15 pm
85Kg is going to be a conservative assessment, reckon the road load is more on the money.
My old Superlight was weight limited to 85Kg (I think) - I've not been much below that for years and didn't manage to break it in 10 years hard use.
Posted : 27/11/2014 3:17 pm
Much more like it! The 27.2 Alien on my road bike is very light, so not surprised.
Posted : 27/11/2014 3:18 pm
new ultimate alloy 350 - comes with a 90kg limit
http://r2-bike.com/New-Ultimate-Seatpost-Aluminium-Alloy-350-mm-130g
If I've got one Kryton you can have the NU Carbon one for £100 (I used to be the distributor, if you weren't aware). They're about £160 normally IIRC.
Posted : 27/11/2014 3:19 pm
Cheers, all though I feel I must have some KCNC on my bike (Stem is OD2 so no joy there, bars will be Mt zoom low risers, with Ti faceplate bolts no less).
I reckon this bike is approaching sub 25.5lb now even by my digi-kitchen scale calculations.
Posted : 27/11/2014 3:24 pm
See I'd avoid KCNC stuff where I could. It's light and good value, but I think it looks cheap and nasty!
Posted : 27/11/2014 3:37 pm
Well, you live in Surrey and me in the slums of North London... 😉
Posted : 27/11/2014 3:39 pm
Sussex now daaaaahling. Couldn't afford a GU postcode!
Posted : 27/11/2014 3:42 pm
Race Face Next SL has a lovely clamp system and the two I've owned have been faultless.
Not really interested in weight myself, but they feel very light. Also quite comfy.
njee20 - Member
How very dare you!?! 😉
I fitted it to my bike because I thought it looked pretty good (and part of it was because it's a name you don't see everywhere).
My seatpost looks quite worn now, I will admit, but I think that's because to get the bike in my car, I remove the seatpost so it's in-out all the time.
Funny thing was, although I didn't buy it to save weight I did expect it to be a bit lighter than the stock Specialized stuff, given the price of it all....but there was very little in it (although the seatpost is longer and bars wider, so perhaps not a fair comparison).
Just goes to show that to save weight you shouldn't just assume that the standard finishing kit is cheap and heavy!
Ha, personal innit! I'd not not have it (have used their skewers before), just not a brand I'd choose on looks alone!
Posted : 27/11/2014 3:44 pm
In my case I have weighed what I'm taking off, vs what I'll be putting in. The SL on Giants alloy stuff is a bit of misnoma...
Posted : 27/11/2014 3:51 pm
SL on early Rock Shox forks stood for "Sport Level" no inference as to the weight.
That's all fact fans!
Posted : 27/11/2014 3:52 pm
SO what would you get njee, in terms of a similar price point and weight? I was looking at KCNC too, but a few options never hurt.
Posted : 27/11/2014 4:53 pm
I'd probably get the KCNC, but also consider:
- Woodman Carbo EL
- New Ultimate alu or carbon
- Carbon Cycles
- Generic Chinese carbon
Not to au fait with where prices are these days quite honestly, the Woodman and NU (particularly carbon) will likely be a chunk more expensive.
Or just do it properly and get an MCFK one 😉
Posted : 27/11/2014 5:01 pm
FWIW, I ordered the KCNC 350mm 😀
Posted : 27/11/2014 5:09 pm
