Which is stiffer - ...
[Closed] Which is stiffer - 10mm through axle or 'bolt up' ?
[#5669341]
So I have a long travel rear end but with open dropouts and a 135mm spacing.
Hope Pro II Evo rear hub.
Wanting the stiffest set up. Considering :-
1.DT Swiss RWS,
2.Shimano SM-AX80 (as specified for Zee hubs),
3.Sun Ringle conversion axle or
4.convert the hope axle to bolt up.
None of them are prohibitively expensive but I would like to know if anyone has experience of comparing or knows which would give the stiffest set up ?
Cheers.
Posted : 06/11/2013 4:05 pm
Bolt through slightly stiffer than 10mm we IMO
Posted : 06/11/2013 5:14 pm
Couldn't tell any difference personally (both Hopes). Bolt-up was lighter though and I liked the 2 points of retention. Not that a QR should come loose anyway mind.
Posted : 06/11/2013 5:49 pm
A QR is completely out of the question !
Anyone else ?
Posted : 07/11/2013 11:43 am
I meant a 10mm for the bolt-through, rather than a standard QR.
Posted : 07/11/2013 11:46 am
I've had DT 10mm RWS, Superstar 10mm through axle and 12mm Hope bolt up. Cant say I could tell any difference between them stiffness wise but immediately way stiffer than QR. I think the DT RWS system was easiest to use but Superstar works OK and best VFM.
Posted : 07/11/2013 11:49 am
The frame may well be the weak link depending on what it is so the axel might not make any difference.
Posted : 07/11/2013 11:50 am
 Euro
I went with a Hope bolt through on my Supreme. I'd be lying if i said i noticed any difference in stiffness, but i could tighten it up a bit more than the qr which was reassuring.
Posted : 07/11/2013 12:26 pm
My hope pro 2 10mm has a Hadley 10mm through axle on my qr frame. Lovely bit of kit
Posted : 07/11/2013 12:42 pm
Mmmmm....mixed responses and thank you.
It's for a Specialized Status - so yes, the frame is a bit of a weak link. Considering it's budget DH and uses some parts common to the SX trail, like the chainstays, it's a shame it doesn't use the final version that had a 142 x 12 rather than the older versions with 135 x 10 :-(. (my Status is frame only, so didn't come with the stock axle and Spec UK seem incapable of supplying one !)
I use bolt up on an Orange 5, it's stiffer than QR but wasn't sure if it was stiffer than the DT Swiss RWS which I tried but stangely seemed to promote brake resonance which meant I went back to bolt up.
As I have the DT Swiss I think I'll start with that and I have seen that some Spec sponsored pro riders (eg. Luca Shaw) also use it on the same bike.
Any further experience welcome.
Posted : 07/11/2013 12:48 pm
Hey Greeble, the Hadley axle looks good.
I wondered if there was a chance of it slipping as the contact pieces are smooth and not knurled or textured like others ?
Posted : 07/11/2013 12:51 pm
I had a cheap Susperstar 10mm QR in a Hope rear hub and it stiffened it up nicely. Not tried a bolt up 10mm to compare with though.
Posted : 07/11/2013 1:15 pm
10mm Bolt-Up on a Hope Pro2 was noticeably stiffer than the Superstar 10mm thru-axle thing on the Ventana's I had. And Ventana El-Ciclon's are mega stiff at the back anyway.
Posted : 07/11/2013 1:23 pm
Steel4real
There is zero slippage one end of the axle has a small notch that sits in the dropout
Posted : 07/11/2013 1:29 pm
Nice one Greeble - the Hadley axle does look very nicely made.
I was actually thinking about slipping out of the drop out but then thinking a bit more, a smooth surface (the axle 'nut') on another smooth surface (the drop out) is probably going to have quite a lot of friction, especially when done up tight.
Posted : 07/11/2013 3:33 pm
Did you get sorted Marcus?
I'd also concur with Tom (Tomaso) re the cheap superstar 10mm oversize QR thingy. That's what I have on the Five in a Pro2 bolt-through.
Previously had it on a Meta 5 and it stiffened that up no-end, so swapped it onto the Five from day-one.
Posted : 15/11/2013 3:47 pm
