I have two bikes i intend to fit Hope pf bottom brackets to....
i) YT tues, 83mm wide, 46mm id for a 30mm Truvativ chainset
ii) Stumpy, 73mm wide, 46mm id for a 24mm Shimano chainset
which Hope BBs do i need to buy?
thanks
Bump for evening experts....
Part nos on here:
Youll also need the fitting tool.
The stumpy is simple but I know sram bb30 cranks don't play ball with hope 30mm bottom brackets, I'd have a word with hope as it may be different with fat/boost bb shells.
the mtb industry certainly deserves a kick in the nuts for the dog's breakfast they have served up in terms of BB standards.
If, like me, you are tight and already have a headset press then you might not need the specialist tool. I found the head on a M20 bolt (we have these lying around the workshop) does the same job as the Hope 30mm hex tool.
They don't? I've got a SRAM bb30 chainset running on one in my Turner frame.
Thanks. I have the tool from fitting a Hope BB to another bike.
