I'm changing my forks to some fox 32 but they are post mount and I have a hope momo mini(the black and gold one)which are IS,is this the right adaptor I will need http://www.chainreactioncycles.com/Models.aspx?ModelID=13735
It's the correct adaptor, but you're also going to have to get a new rotor. In case you missed it; the adaptor ups your rotor size by 20mm.
To what size rotor, Im thinking of the same and im running 203 front.
Like I said, the adaptor means you have to go to a rotor 20mm larger than the caliper would usually fit.
Thanks threefish,i'm running a 183mm rotor and a have a a 203mm rotor
...I'm running a 183mm rotor and a have a a 203mm rotor.
Not sure that the 32 is built for use with such a big rotor. I'd say it's worth checking out before you proceed. Give Mojo a call and heed their advice...
