Got 2 almost identical pairs of Vanillas, only difference is one is QR, the other is QR15.
Which pair should I fit to the Blue Pig and which to the Yeti 575?
Yes I'm bored!
mmmmm.you need 15mm bt on both tbh.
That ain't gonna happen TLR
It depends a bit on the builds on each really, 15mm on whatever has the burlier build.
Apart from the wheels the components are quite similar
Ah then put the QR15 on the one with the QR15 front wheel!
Just consider what you are going to use the bikes for, personally I'd put the QR15 on the Yeti as you tend to get more speed and into more trouble with FSussers and the stiffer front end will help you out a bit.
That was my train of thought too akira
