Mono M4 rotor size....
[Closed] Mono M4 rotor size.?
[#931200]
Would I be right in saying the M4 had a 183mm rotor instead of 180mm.?
Posted : 07/10/2009 8:21 pm
I've got some of the first M4 Monos & they're 180
Posted : 07/10/2009 8:36 pm
Depends on the mount you use. From the Hope website they do both sizes of rotor. I'm using 180s with mine but I suspect a 183 would fit (from what I can see, an extra 1.5mm will fit into the setup I've got.
Posted : 07/10/2009 8:37 pm
Posted : 07/10/2009 8:39 pm
Hmmm have to dig the tape measure out in the morning.
Cheers.
183 for post mount, 180 for IS. You may be lucky and get a 183 to fit, sometimes there's enough clearance, sometimes not.
Posted : 07/10/2009 8:58 pm
I have run both 180 and 183 on my M4 IS mount in the past no problems.
Posted : 07/10/2009 10:04 pm
What coatesy said.
Posted : 07/10/2009 10:05 pm
