Which fork for a sp...
[Closed] Which fork for a specialized camber 2013 ?
 jeb
[#5412664]
Hello
Just got a 2013 frame, so which fork should i get, 100mm 120mm... is RS making one with all travel spacers?
i found this fx:
http://r2-bike.com/ROCK-SHOX-Suspensionfork-29-REBA-RL-SA-2014-120-mm-QR15-tapered
Posted : 11/08/2013 7:59 pm
I have a 100mm Fox on my Camber. I reckon that a 120mm would be fine too. I quite often find myself using all 100mm of travel.
Posted : 11/08/2013 8:10 pm
Posted : 11/08/2013 8:44 pm
Have a look on Merlin cycles. I picked up some 100mm Rebas there with the all travel spacer. With that removed they went up to 115 (120 if you like less negative pressure than positive) but I think they have changed now.
Posted : 11/08/2013 9:19 pm
I'm running 120mm on my '13 camber 29er. Happy with that, slackens it out a bit.
Have tried the '13 100mm reba's from my carve on it to see what it's like - prefer the 120mm.
Don't forget that '13 onwards RS forks can't be adjusted with the travel spacer - need a new air spring assembly. If you want easy internally adjustable RS forks look for anything '12 or older (reba, revelation etc)
Posted : 11/08/2013 9:25 pm
