Which fork dimensio...
[Closed] Which fork dimensions to buy
[#10298034]
hi guys wondering if you can help me out just been reading the forum I currently have a merida big trail but it came with different spec forks than listed, so I am looking at upgrading them the current ones are 27.5+/29″ 51mm offset boost forks, I am running 27.5 boost wheels with a 2.6 front tyre. should I be looking at replacing the forks with exactly the same as above or will I be ok looking at 27.5 boost forks with a 44mm offset I cant see my self ever running a 29″ wheel in the frame any help would be great cheers guys
Posted : 27/10/2018 9:46 pm
There's a thread about the effect of fork offset, here:
https://singletrackworld.com/forum/topic/anyone-have-first-hand-experience-of-playing-around-with-fork-offset/
My personal experience is that I am unable to tell the difference between 44mm and 51mm offset on a 29er. Whereas the head angle change of just a couple of degrees made a huge difference. Make of that what you will.
Posted : 27/10/2018 10:55 pm
Cheers i posted in there as well .
Posted : 27/10/2018 11:11 pm
