Which Derailleur Ha...
[Closed] Which Derailleur Hanger Alignment Tool?
 Mat
[#6163956]
Any thoughts on what derailleur hanger allignment tool to get? I need to straighten out the hanger on my inbred. I've been looking at the following:
[url= http://www.wiggle.co.uk/lifeline-derailleur-hanger-alignment-tool/ ]LifeLine Derailleur Hanger Alignment Tool[/url]
[url= http://www.freeborn.co.uk/park-tool-usa-dag2-derailleur-hanger-alignment-gauge?gclid=CLHGjujckL4CFa-WtAodVzEAsQ ]Park Derailleur Hanger Alignment Tool[/url]
[url= http://www.wiggle.co.uk/cyclus-gear-hanger-alignment-tool/?lang=en&curr=GBP&dest=1&utm_source=pla&utm_medium=base&utm_campaign=uk&kpid=5300022120 ]Cyclus Derailleur Hanger Alignment Tool[/url]
Thanks!
Posted : 03/05/2014 10:45 pm
Mat ( howard ?) i have one if you just want to borrow for a single job.
Mines is the cyclus.
Posted : 03/05/2014 10:50 pm
1 rear QR axle (threads into the mech hanger), 1 bit of threaded bar (to go in the dropout and give you a straight line to compare against. The trouble with ones that compare against the wheel is your wheel might not be that straight.
Posted : 03/05/2014 10:56 pm
I've got the cyclus one, it works.
Posted : 03/05/2014 10:57 pm
Adjustable spanner.
If your wheel is sufficiently out to be an issue to straighten by then you are in trouble.
Posted : 03/05/2014 10:58 pm
Your drop outs would have to be welded on at a serious angle....
Or your wheel tacoed like a pringle , the beauty of the tool is that it allows you to check it in all planes not just a single plane like the two threaded rod method.
Posted : 03/05/2014 11:01 pm
It's the disc brake era, none of my wheels are round! It's all inaccuracy that you don't need, while there's other methods that avoid it.
But, why do you think the 2-rod method can only do one plane? It's no different from the "proper" tool in that regard.
Posted : 03/05/2014 11:13 pm
Inaccuracy ? My wheels are round.and straight.( and so are my hangers )
Yeah i just had a think your right it can do both planes , im just not convinced it amplifies the bend enough to not introduce a different set of inaccuracies.
Posted : 03/05/2014 11:16 pm
screw another wheel if you have one into the mech hanger thread then adjust it untill thw wheel is in plane
