Which CX brakes?
[Closed] Which CX brakes?
[#4301226]
My Genesis Day One has mini v brakes. Would cantis like Avid Shorty's be more powerful? And would it be necessary to have some sort of thing on the headset to hold the cable in position?
Posted : 27/08/2012 1:31 pm
 Bazz
I just recently swapped out my tektro cantis for mini v's, all the while i was using the cantis i was tottaly happy with them, now that i've got mini v's i don't think i could ever go back. Stick with with them imo.
Posted : 27/08/2012 2:43 pm
Agreed. Mini v are more powerful than canti brakes. However, they feel more spongy (due to mechanical advantage) and need to be set closer to the rim.
Posted : 27/08/2012 2:52 pm
Ok. Must just be rider weight that's the issue 🙁
Posted : 27/08/2012 2:56 pm
If its anything like my Day One the mini V's eventually seize up as the pivots corrode. I bought some XLC ones to replace them which worked lots better and have brass bushings, very powerful. More so than my road bike brakes. They were like these though i got them from parker international.
https://www.greyville.com/products/7083
Posted : 27/08/2012 3:00 pm
The front one has done just that. I've ordered two of those you suggest. £8 each. Seems very cheap, presume they're just not gucci, rather than shi te?
Posted : 27/08/2012 4:20 pm
Worth considering some decent pads, rather than the stock ones. That'll help too.
Oh, and yes, mini vees are better and no brake judder....
Posted : 27/08/2012 5:03 pm
Assuming it is singlespeed, you could use some proper V-brakes, with suitable levers. eg Tektro RL520 have the correct pull for V-brakes.
Posted : 27/08/2012 5:24 pm
