Which cone spanner....
[Closed] Which cone spanner...
[#3694947]
15mm SLX front hub is losening off, lockring obviously not tightened in the factory. What cone spanner(s) do I need, is it the same model as the 20mm version?
Posted : 19/02/2012 11:17 pm
one in a million - I thought they did them up with a scaffold pole!
Posted : 19/02/2012 11:21 pm
I know, I guess this way is preferable in some respects, especially if I get to pick up a comedy oversized spanner.
Posted : 19/02/2012 11:24 pm
They dont specify the 15mm hub on the shimano tech docs site, Id be surprised if the went for a different lock nut size. I have the big one for my 20mm XT.
Posted : 19/02/2012 11:26 pm
Mine was loose too after a couple of months.
Could do with knowing what tool needed.
Can you not measure the nut? 20mm shimano hub uses 28mm cone spanner as far as I'm aware
Posted : 19/02/2012 11:30 pm
Not until i get home tomorrow and was hoping to pick one up before then.
Posted : 19/02/2012 11:31 pm
So it seems it's this: http://www.chainreactioncycles.com/Mobile/MobileModels.aspx?ModelID=29170 has anyone actually used one with a 15mm hub? Do they come as a pair or can you get an adjustable spanner on the disk side when you remove the centrelock locking?
Posted : 20/02/2012 7:47 am
Ok, that's not the right one. The sizes are 23 and 26mm for future reference
Posted : 22/02/2012 9:07 pm
