Which Chinese carbo...
[Closed] Which Chinese carbon disc road wheels??
[#6315680]
Thinking of getting a set of clincher disc road wheels for my Ti Tripster (currently using open pros on hope hubs).. I have a budget of about £350.
Havent a clue which ones?? What width, weight etc..
Anyone help?
Posted : 04/07/2014 7:52 am
Watching closely.....
Posted : 04/07/2014 10:52 am
Is the Tripster standard QR?
I had the same decision for my Domane but it's bolt through front and rear and hub choice for 11 speed was limited. Went for Pro2's on NoTubes Alpha in the end. The novatec equivalents where heavy as and I didn't fancy commuting on carbon rims 🙂
Posted : 04/07/2014 11:10 am
NoTubes Alpha
Discs or standard 340's? I was going looking at these, but the Disc version has a quoted weight higher than the standard rim braking 340's and higher than Open Pro's....
Posted : 04/07/2014 11:46 am
I went for the Alpha 400 Disc, 340 Disc is the same weight and the standard 340 isn't supposed to be used with a disc hub.
Both ~420g
Posted : 04/07/2014 11:47 am
I got soem from lightbicycle, with novatec disc hubs
I use them with rim brakes at the moment so can't comment on the braking
were between 3-400, including import duty etc
Posted : 04/07/2014 12:20 pm
Just noticed how much stronger the £ is against the $
Still slightly overwhelmed with choice.
Im thinking 23mm wide and 38mm deep rims and novatec hubs.
something like these.. http://www.ebay.com/itm/wider-carbon-38mm-wheels-road-bikes-700c-clincher-/321325967380?pt=US_Wheels_Wheelsets&hash=item4ad0852814
Is there any benefit of U shaped rims?? what finish? Weight?
Posted : 04/07/2014 8:50 pm
