Which budget trail ...
[Closed] Which budget trail GPS?
 hora
[#708586]
With easy to download maps (of most trails?) and easy to follow?
Posted : 14/07/2009 9:58 pm
OS map and a compass?
Posted : 14/07/2009 10:00 pm
You want a mapping GPS? That's not "budget"
Posted : 14/07/2009 10:02 pm
Memory Map or Quo + Garmin eTrex H + Paper map of where you are going + USB to serial convertor
The SatMap Active 10 is pretty good, but not budget. The Garmin Oregon 300 is not great.
Posted : 14/07/2009 10:04 pm
 deft
Don't need memory map, just http://wtp2.appspot.com/ and a free copy of EasyGPS 🙂
Posted : 14/07/2009 10:06 pm
deft - very good!
Posted : 14/07/2009 10:12 pm
[url= http://www.amazon.co.uk/exec/obidos/ASIN/B000UNFLNS/300002855-21/?m=A3P5ROKL5A1OLE ]Garmin etrex legend hcx[/url]
Look at the number of [url= http://www.waypoints.com/etrex.html ]waypoints per route[/url] before you buy. 250 is barely enough.
http://sites.google.com/site/talkytoasteruk/ukmaps
free topo mapping but it does require 170MB mapping memory (micro sd card)
http://www.bikehike.co.uk/
plot your route on bikehike
http://www.easygps.com/
upload it to the garmin with easy gps
Posted : 14/07/2009 10:47 pm
 Solo
I've an ex-company windows smartphone.
I've a [i]free[/i] version of MM.
Job done.
S.
Posted : 14/07/2009 10:48 pm
What happens if it rains and the battery runs flat after a couple of hours and you can't read it in sunlight and you can't get a handlebar mount though.
Posted : 14/07/2009 10:51 pm
Abductee- you work around those problems by taking them into consideration prior to the ride. Just like you would take a mapcase, learn how to use a compass properly, learn how to use catch features and other appropriate methods if you were navigating traditionally.
So you take a spare set of hig power batteries, look at the screen in the shade and carry the unit in your pocket. It's hardly rocket- science. Although I suppose the technology to put the GPS satellites into position IS rocket science, quite literally.
Hora- FWIW I've just traded in my old eTrex legend for [url= http://www.memory-map.co.uk/road_angel_adventurer_satnav.htm ]null[/url][url= http://www.memory-map.co.uk/road_angel_adventurer_satnav.htm ]this[/url], A Roadangel Adventurer 7000. I already have a lot of Memorymap coverage so I was getting a bit fed up with not being able to use it when I was out and about. The £50 trade in suited me just fine as my Garmin eTrex was getting a bit tempremental to put it mildly but it has had seven years of hard use.
How about you buy/ obtain the cheapest possible working GPS unit and then use it to then get the £50 discount? Ebay is your friend
Posted : 15/07/2009 1:02 am
 hora
I'm almost fainting at the prices -£230 for a Roadangel Adventurer 7000?!!! 😯
Garmin eTrex Legend HCx- Im liking the look of that one.
Posted : 15/07/2009 8:09 am
Etrex are good & easy to use
Just be aware that you don't follow a map - as such - you either follow a line on the screen or the compass needle, it's very intuitive though
You also need to either pre-prepare a route or use one someone else has done
The waypoint issue is really a non-issue as you can simply upload routes as tracklogs
Memory Map is available very cheaply [ 😉 ] from the usual sources
Posted : 15/07/2009 8:27 am
I went for the free bikehike.co.uk & Garmin geko 201 option.
plan the route on the site, DL & UL to Geko.
you can't create a new plan on route as only the track sits on the Geko, however if you print the map from bikehike & carry it, you know where you are & where you need to be - the rest is old fashioned navigation 😉
Posted : 15/07/2009 8:29 am
I planned two routes on Memory map and put them on my old Summit as Tracklogs for our trip up to the NY moors and was really impressed with how easy it was to follow.
Went wrong twice - once when I had the scale(zoom) wrong and once where I was unable to see a turn was required due to the scarry speed I was doing on some rough stuff.
Got the Summit mounted on my bars and can read it easily.
I had nice big prints of our route from MM to hand round our group too, which was handy.
Posted : 15/07/2009 9:03 am
 hora
Garmin geko 201? - a good price as well.
Posted : 15/07/2009 9:05 am
I have the Geko 301. Just got a few more bells and whistles that the 201.
Its the smallest, lightest GPS unit I'm aware of, but it can struggle under tree cover. I understand the high sensitivity etrex is much better in this regard.
Posted : 15/07/2009 9:37 am
Hora, I have a Garmin Etrex H for sale... drop me an email if you might be interested. I may also be able to sort you out some mapping software.
Posted : 15/07/2009 9:50 am
Just pointing out the differences here. Please don't take is as a personal attack on whichever unit you own.
The Geko and Etrex H don't do mapping the Legend HCX does and it has a colour display which displays the topo maps properly It's easy to read in sunlight and has longer battery life than the monochrome model it replaced.
The Geko and Etrex H do 125 waypoints per route the Legend HCX does 250. I find this feature very important. Your mileage may vary.
The Geko doesn't have the high sensitivity receiver. It will lose signal in woods and deep valleys. I own the Legend CX and it does this.
H=high sensitivity C=colour X=micro sd card slot
Barometric altimeter and magnetic compass on the higher models reduce the battery life when turned on and I don't really see the benefit
Posted : 15/07/2009 6:56 pm
handy to know.
I find using waypoints to be a pointless waste of memory and limiting. I always upload tracks.
Posted : 15/07/2009 7:14 pm
nokia e75
Posted : 15/07/2009 9:06 pm
I've got an eTrex legend, I can highly recommend it.
Posted : 15/07/2009 9:14 pm
scienceofficer
If you upload a route and select navigate it will tell you the bearing and distance to the next waypoint. If you upload a track how do you follow the track? Do you try to make the little arrow stay on the line on the map display?
Posted : 16/07/2009 5:55 pm
The same can be done with a track, but rather than a straight directional bearing to the next wayppoint (which may not be the same direction of the actual route) it re-traces the track one has prepared prior to going out on the ride. I follow a dirty great direction arrow, and keep it pointing straight ahead. The pre-drawn track isn't displayed at all.
I find that navigation the way I describe reduces map stoppage time over the waypoint technique, which is really just re-creating the map and compass methodology.
Posted : 16/07/2009 6:48 pm
Sounds good. Do you do this by selecting the saved track and then selecting TracBack?
Posted : 16/07/2009 7:34 pm
Ive got the whole of the UK in MM so would prefer to stick to this if possible. Could I upload a particular map onto the card for a Legend HCX?
if not does anyone use MM on a gps
thanks
Posted : 16/07/2009 10:46 pm
to the guy that said e75 - what software you using on it ?
got googlemaps and nokia maps on mine and neither are any good for mtb .....
Posted : 16/07/2009 11:01 pm
smudge
You cant upload the maps from memory map but you can plot a route on it and upload that to the gps.
The Etrex uses vector graphics not bitmaps like those on memory map.
To upload maps to the GPS you need to buy the Garmin Mapsource products or use one of the open source mapping solutions like talkytoaster.
Posted : 16/07/2009 11:45 pm
Thanks Ab's
Posted : 16/07/2009 11:48 pm
Yes, on the Geko you can use 'Navigate to..' from the beginning point or the end point.
Posted : 17/07/2009 9:45 am
Trail rat - You can use [url= http://www.viewranger.com/ ]Viewranger[/url] on symbian phones.
Being using it for 3 years and it is the tits on toast.
You can download OS map tiles over GPRS now which is REALLY useful
Posted : 17/07/2009 9:49 am
