Hi
Can never figure these out! Running a 100mm Fox fork with Hope Mono Minis, pic here http://sdrv.ms/1apbOlC
Have choice of disks, 185mm in picture but 160mm is fine.
any idea what adapter I need? If you have one for sale let me know or please post a link to one.
Aaron
Post to IS. Not got one for sale though sorry
Thanks, would this be it?
http://www.chainreactioncycles.com/shimano-mount-adaptor-front-post-to-is-160mm/rp-prod13743
the thing I find confusing is that the holes are threaded, my fork is threaded as is the caliper, I would have thought clearance holes would be better?
or is this the right one http://www.chainreactioncycles.com/hope-mount-adaptor-front-is-to-post-20mm/rp-prod13735
Can't see why it should be threaded. Surely you'll need a bit of movement to line it up as you said. But I've never used Post to IS so I could be wrong.
if you wish to go for a 160mm rotor you'll need the kcnc one
cheers chaps, got one (I hope its the right one!) on the for sale section.
thinks its this
If you don't want to go up in rotor size then the [url= http://clee-cycles.co.uk/esite/P1043/product ]clee cycles[/url] KCNC adaptor allows you to fit IS brakes to a Post mount fork with no change in rotor size.
This is a set of 180mm Mono Mini's fitted to a RS fork. No change in rotor required.
thread update, tried the +20mm CRC one http://www.chainreactioncycles.com/hope-mount-adaptor-front-is-to-post-20mm/rp-prod13735
and you would need a 200mm disc, bought for a fiver off here so if anyone needs it let me know!
Went for the Clee one as recommended by bigG and fits perfectly with the 180mm disk that I have on the bike, don't really understand why a 160mm wont work but hey ho got the bike running again!
Now all I need to sort out is the disc rubbing on the fork!!!
