Which bar tape?
[Closed] Which bar tape?
[#4819163]
The cheap stuff that came on my B'twin is already very thin. So what stays plump and adds a bit of comfort? I have thick grips on my mountain bike I was hoping I could get a bit bigger on bar tape?
this any good?
http://www.chainreactioncycles.com/Models.aspx?ModelID=59631
Posted : 31/01/2013 2:20 pm
Dunno.
The thicker Bontrager stuff is very good though.
Posted : 31/01/2013 2:30 pm
I use lizard skins dsp stuff.. expensive, but worth it i think..
Posted : 31/01/2013 2:44 pm
The lizard skins dsp does keep coming up in reviews. Is it a gel type lining to it?
Posted : 31/01/2013 2:53 pm
Lizard Skins is quite nice, grippy even when wet and semi-cushioned. I use either that or Spesh bar phat stuff inc. the pads under it.
Posted : 31/01/2013 3:02 pm
Specialized 'Bar Phat' I think it is on all of my roadbikes (white of course as it is the fastest of all of the coulours)
I don't get the stuff with pads in I just cut up old mouse mats, it works surprisingly well.
Posted : 31/01/2013 3:04 pm
Arundel Gecko Grip is great, similar to lizard skins but a nicer feel if you prefer not to wear gloves. Fizik is good too the flocked type.
Posted : 31/01/2013 3:06 pm
i like the bontrager stuff on my cross bike but (after about 3-4 years use) its wearing on the bends.
easton is similar and really nice.
zip is also nice and i find really hard wearing, on my road bike also 3-4 years and no wear like the bont.
Posted : 31/01/2013 4:35 pm
Cinelli Gel Cork stuff is good. Comfy, nice colours and a decent price too.
Posted : 31/01/2013 4:40 pm
I like Fizik bar tape.
For more comfort, you can get Fizik "bar gel" which goes underneath the tape. http://www.chainreactioncycles.com/Models.aspx?ModelID=27914
I half-like my Fizik. It went on easily which is a bonus, and it's durable. But it's a wee bit edge-ey, you can really feel where the tape wraps are. I don't like it without gloves. Still, good grip and comfort
Oh, also it's fairly stiff so was a total balls to get into my bars at the end, but ymmv- I think the bars are quite thick. But the upshot was their end caps wouldn't fit and actually getting a nice wrap-in was hard work.
Posted : 31/01/2013 4:42 pm
 Solo
[i]Which bar tape?[/i]
Posted : 31/01/2013 4:45 pm
Single layer of Fiz'ik microtex and a bit of mtfu
Posted : 31/01/2013 4:48 pm
I`ve used Fizik in the past and found it to have a good blend,of loooks,grip and durability.
Goes on easier if you leave the roll on the radiator before applying.
Next time I feel I could do with a bit more cush so might try Lizardskins or Arundel Gecko.
Posted : 31/01/2013 5:00 pm
If you must, although I've never felt the need, rather than wasting money on the gel strips for under your bars you can use a strip of your old bar tape to thicken things up
Posted : 31/01/2013 5:08 pm
Stella Azzurra Tecno-Spugna - partly for the name, partly because it works and partly because they do a really nice sort of dark Prussian blue version. And the Easton stuff works decently ime.
I tried a set of under-tape gel inserts for a while, felt really odd and wrong to me, though obviously that's just personal taste and I don't have any... 😉
Posted : 31/01/2013 5:27 pm
Double wrapping might be cheaper than fat tapes. No idea if it's a long-term solution but it always get mentioned in bike prep for the cobbled classics.
Posted : 31/01/2013 5:38 pm
On the subject of bar tape, which way are people wrapping? Bottom up would stop dirt/water running between wraps. However, top down gives a cleaner look as no bits of tape to hold it all on.
Posted : 10/02/2013 1:40 pm
Prologo.
Used/raced/abused for years. Always holds up
Start at the bottom, leave about half a width of the tape outside of the bar end (for bung) and begin to tape, pull the tape tight on each wind.
Posted : 10/02/2013 1:46 pm
Lizard Skins DSP is lovely stuff and they do a 3.2mm version now as well for more cushioning.
Posted : 10/02/2013 1:53 pm
Fizik Microtex
Posted : 10/02/2013 4:36 pm
Charge U-Bend is lovely.
Posted : 10/02/2013 4:55 pm
