As above which products have you found the best for cleaning disc brakes and stopping glasses from fogging up?
I use these cos I'm a speccy four-eyes: http://www.jklclothing.co.uk/p-Portwest_Workwear_Fog_Buster_Towelettes_PA05-(6243).aspx
They're great. Only problem is it washes off in the wet but tbh if you're riding with specs in the rain then fog is the least of your issues.
I heard a little bit of wee helps, you should try it.
http://www.visorvision.co.uk/shop/index.php?cPath=25
This stuff is awesome, just don't touch it after 'painting' a coat on. Bottle is best value
After trying a few different brake cleaners I have resorted to using meths. This was after speaking to hope who recommended it as it leaves no residue when dry. its also about 1/5 of the price of a branded cleaner.
For anti-fogging - Rain-X (recommended by 'the late' TJ and works a treat)
I've not come across any products that will do both... 😉
I buy disc brake cleaner in 5L drums from my local tool supplier, just under £11.
I use meths, no problems and it's cheap. Initially started using it as I couldn't find any IPA, but pleased to see above that Hope use it too...
