Which 650b+ tyres
[Closed] Which 650b+ tyres
[#8222696]
Want to get a set of 3" tyres for me new Stooge and looking for options, the Nobby Nics look like good option but not sure of how they wear ? Will be run tubeless aswell
Posted : 11/12/2016 10:21 pm
Well I loved the vittoria bomboloni that I had on the front of my solaris, however the clearance wasn't good enough and started to wear the insides of the fork. If I had a boost fork and clearance at the back, it would be top of my list. Never been a fan of Schwalbe personally.
Posted : 11/12/2016 10:54 pm
Running maxxis rekon + 2.8". Plenty big enough, loads of grip but roll really well. Went up easily tubeless as well. Tread pattern is like a huge Ardent with a bit of High Roller 2 mixed in.
Posted : 12/12/2016 10:40 am
Found Nobby Nics OK, but kept puncturing the rear on jumps and drops, any kind of rocky landing and it was done for, unless I ran it at 35+ PSI, which defeats the purpose.
Running Rekon rear and DHF front now, seems to be better than the Nics at everything.
Posted : 12/12/2016 10:42 am
I have a set of Specialized Purgatorys in 3" on a 29" Stumpjumper. I've only had a chance to ride at Swinley but I'm really happy with them. Capable of running low pressures (under 15 psi - I must order a decent pressure gauge) and I've not lacked for grip once. Seem to roll well - certainly well enough for my liking.
Posted : 12/12/2016 11:46 am
watch out for rocks...
Posted : 12/12/2016 11:48 am
What's the clearance on your Stumpy like, and what year is it Siwhite? I've tried a 650 x 2.5 in mine but want to try 2.8 or 3.0. Mines a 2016 Stumpy 29er.
Posted : 12/12/2016 4:04 pm
Happybiker - clearance is fine. About 20mm above the top of the tyre. Closer to the sides - about 5mm each side - but I keep away from epic mud if at all possible. Front (29" Pikes) is about the same.
Posted : 12/12/2016 6:04 pm
I might give them a go in the summer. I've currently got a 2.8 NN up front which will go in the rear and then I'll look at someone a bit bigger to stick up front.
Posted : 12/12/2016 11:22 pm
