Which 140mm Forks
[Closed] Which 140mm Forks
[#5322434]
I’m looking for a set of 140mm for the TRc I’m building, got about £500 to spend.
Top of the list at the minute is a set of RCT3 Rev’s, I also like the idea of the 34mm X-Fusion Slants but the fact you can only fit a 203mm rotor is putting me off.
So, anyone got any other suggestions?
Posted : 10/07/2013 10:16 pm
You want a rotor bigger than 203?
Got a set of 140 revs for my buzzard build and really liking them so far. Heard a lot of good things about the slants but not tried them
Posted : 10/07/2013 10:46 pm
[url= http://www.bike24.com/1.php?content=8;navigation=1;product=37711;page=1;menu=1000,2,121;mid=69;pgc=0 ]DT Swiss XMM 140 QR15 - £430ish[/url]
Posted : 10/07/2013 10:50 pm
I was in your position earlier in the year. I went for some second hand 36 floats and dropped the travel down.
Now I've fitted an avalanche damper. It's the perfect fork.
Posted : 10/07/2013 10:55 pm
Clobber - Member
No, smaller 🙂 . The Slants are 203mm and nothing else unfortunately, as I'm pretty sure I'd be buying a set if this wasn't the case.
Think I'm just going to go with the Rev's, not sure on DT's and don't want the weight of the 36's.
Posted : 11/07/2013 8:27 am
New Pikes (bit pricey yet tho!!)
Could chop down the disc mount on the slants!!!
Posted : 11/07/2013 12:30 pm
Onzadog - intrigued about the avalanche damper for your 36's, i'm guessing you'd recommend the upgrade then? I've got a lowered 140mm 36 float r on my ti slackline, love the stiffness but the damping could be better.
Apologies for thread hijack.
Posted : 11/07/2013 1:04 pm
I think there's a tweaked version of the slant that allows a smaller rotor
Posted : 11/07/2013 1:06 pm
 br
Magura Thor/TS8's, and they're configured for a 180mm rotor - so also save needing an adaptor.
Posted : 11/07/2013 1:08 pm
Gee76 - Member
Pikes to pricey and don't think there’s a 140mm? Certainly won't be chopping anything other than the steer.
honourablegeorge - Member
Not sure about that, I'll have to give Upgrade a ring but both the LBS's I've spoke to have confirmed only 203mm.
Posted : 11/07/2013 1:37 pm
Stevede, yes, expensive but well worth it. I've got one on my 160mm van36 and one on my 130mm float 36.
Let Craig know you've reduced the travel and he tweaks the damper at no extra cost.
Posted : 11/07/2013 5:51 pm
fathomer - Member
I read it on Pinkbike somewhere, so yeah, pinch of salt, but worth checking
Posted : 11/07/2013 5:55 pm
