Where's this bolt c...
Where's this bolt come from?
[#12562215]
Working on my bike yesterday as I took it off the stand I heard a little noise as a small bolt fell onto the floor. It's a T10 torx bolt, approx 8mm long. Can I find where it came from? Can I flip. Bike is an Evil Calling, Manitou Mattoc 3 forks, Sram 1X / X0 11 speed gears, hope X2/E4 brakes , One up dropper.
It looks a lot like a reservoir cap bolt but they are all present and correct, or a bolt from the Mattoc mudguard but they are all there. So - what other parts take short a T10 torx bolt? I swear someone has just put it somewhere to fall out to wind me up.
Posted : 02/10/2022 2:56 pm
 DT78
brake pads?
I'd check the calipers and dropper remote after that....not sure...
Posted : 02/10/2022 3:00 pm
Holding in a gear/brake cable frame entry grommet thingy? Looking a picture of the calling, is there one of those expanding wedge things where it enters the swingarm to stop movement?
Probably a bit big, but rebound adjuster on the forks, or damper top cap?
Posted : 02/10/2022 3:02 pm
Throw it in the bin, 5 mins later find out where it came from, spend the next 4 hours with the contents of the bin laid out on your driveway as you hunt for the bolt
Posted : 02/10/2022 3:10 pm
Good guess but nope - they are all molded in with rubber grommets not bolted in.
Checked the rebound adjuster and not that.
Posted : 02/10/2022 3:36 pm
Long-shotting it now. The little bolt that holds the derailleur-hanger onto the frame?
Posted : 02/10/2022 3:40 pm
forget
Posted : 02/10/2022 3:45 pm
Did it sneak out from under the fridge/bench, jump up in the air and just pretend to have fallen off the bike?
Posted : 02/10/2022 3:52 pm
There's a very similar bolt 9n the Hope lever. It holds the dust seal in place over the master cylinder.
The difference is that it's a security torx with a small pin in the middle of the head.
I also had similar bolts holding a head badge on.
Posted : 02/10/2022 3:59 pm
Is it a bolt from the blue?
Posted : 02/10/2022 6:12 pm
Ask it if it’s called Bernie. If it responds then it’s from the seventies?
Posted : 02/10/2022 8:33 pm
Fork rebound knob?
Posted : 02/10/2022 8:39 pm
Cable securing bolt from your dropper post lever?
I love this thread.
Posted : 03/10/2022 12:24 pm
Its one you couldn't find last time you tinkered. It got stuck on the bike , you couldn't find it so replaced it and now it has shown itself to confuse you
Posted : 03/10/2022 12:35 pm
Underside of the saddle?
Repair stand itself?
Or, it was on the repair stand, left over from a previous bike/job, and fell to the floor when you removed this bike?
Picture might be useful, against eg a 10p piece for size reference ... I'm struggling to visualise an 8mm T10 torn bolt ...
Posted : 03/10/2022 12:40 pm
Nope
Like it
Fork rebound knob
Nope. And don't call me a knob.
Nope.
Its one you couldn’t find last time you tinkered. It got stuck on the bike , you couldn’t find it so replaced it and now it has shown itself to confuse you
I just dunno, I can't find a similar bolt anywhere on the bike, I've gone over it with a torch today again. This thing is driving me crazy, perfect way to wind someone up I'd say. WHERE DID YOU COME FROM YOU SHINY LITTLE BASTARD
Pedal pin?
Posted : 03/10/2022 12:42 pm
Shiny little bolt
Posted : 03/10/2022 12:50 pm
Hope brakes? Some models use these bolt to secure the lever piston or to secure the lever pivot
Posted : 03/10/2022 1:16 pm
Are you sure it is what fell? You're not missing a bloody obvious m10 bolt that should be holding a pivot somewhere but found that on the floor are you?*
Bolt that holds the lever of a "maxle"? Shifter cover? The one that stops the receiver nut for the axle falling out of the frame (mine is a v1 following and uses a grub but about the same size)
*I have never done this. No, not at all.
Posted : 03/10/2022 1:23 pm
Those button heads are often used to hold brake discs on but it looks a bit small.what is the thread size?
Posted : 03/10/2022 2:19 pm
Looks rotor ish?
Posted : 03/10/2022 2:23 pm
Another vote for brake rotor bolt. Love the photo.
Posted : 03/10/2022 2:24 pm
Brake hose clamp-thingy on the fork leg?
Posted : 03/10/2022 2:27 pm
Systematic check to every bolt on every component throughout the entire bike.
I think there should be a prize for guessing correctly.
Posted : 03/10/2022 2:28 pm
 a11y
Are you absolutely sure not had any 'mates' over, who've succeeded in ripping the piss by dropping a random bolt?
Posted : 03/10/2022 2:29 pm
I had this recently, turned out it was from the work stand itself!
Ooh, good call!
Rotor bolts tend to be T25
Posted : 03/10/2022 2:32 pm
wishiwascalledsteve
Winner winner! it was on the hope master cylinder, the bolt that holds the lever pivot as suggested!
Thanks all!
Posted : 03/10/2022 2:37 pm
