Where to shim shop
[Closed] Where to shim shop
 mlke
[#6722807]
I've a GoPro handle bar bracket in 31.8 size but would like to stick it on an old skinny size bar. I 'd like to buy a decent shim for the bracket rather than bodge it. I couldn't find anything decent, can anyone help?
Posted : 22/12/2014 3:13 pm
skinny as in 25.4mm or the bar itself at 22mm?
Posted : 22/12/2014 6:27 pm
 mlke
It'll be the 25.4 standard old school size
Posted : 22/12/2014 11:28 pm
I think they do gopro mounts in other sizes, now only 31mm.
However if you go the shim route, a handlebar shim may work, they allow you to use a 25mm bar in a 31mm stem for example.
Posted : 23/12/2014 3:59 am
 JoeG
[url= http://problemsolversbike.com/products/handlebar_shims ]Problem Solvers[/url] make handlebar shims. I don't know if the have a UK distributor; they're part of QBP so are available through most US bike shops.
Posted : 23/12/2014 7:14 am
wrap a bit of old inner tube round the bar ? Adjustable, grippy, very reasonably priced and available right now
Posted : 23/12/2014 9:03 am
Problem solvers stuff is available from Ison
Posted : 23/12/2014 9:14 am
sjs cycles on EBay usually do this kind of thing...
Failing that, just search EBay.
Posted : 23/12/2014 9:17 am
inner tube +1
Posted : 23/12/2014 9:18 am
