Tried SJS but the next-day postage got cocked up now it's too late.
Anyone know anywhere else?
Does it have to be a Salsa.
What seat tube size?
Giant also do one (I have one here but it wouldn't reach you in time)
have you tried the bikemonger?
Thanks for the offer. I really wanted to use the rack I bought next week.. but looks like I won't be able to.. I can probably get a generic one but quite fancied a Salsa one.. having said that the rack isn't the Salsa one either so maybe.
got a standard seat clamp ?
drill it out
Take the supports - put one on one side - fit a long enough m4 or m5 bolt through the support - through the seat clamp then through the other support.
put a nut on the other side.
cut the excess thread off and file the sharps away.
Its how we used to do it before such items became common place.
Ive even in the past made "extensions" if the supports were not long enough
I have a brand new Salsa 35mm in my box o' spares, see below.
This is the model that doubles as a seat clamp (i.e. : you can't fit it anywhere on the seat post)
Any good to you?, i bought it for a neighbours bike but he decided he didn't need it.
£15 posted 1st class or i could do it next day delivery.
come on, get creative!
- use the standard seat clamp, but replace the bolt wiht length of threaded bar of same thread size, but longer so it sticks out on each side, then one use nut to clamp tight to hold seatpost, then mount rack stays to the ends of bar sticking out, then two more nuts on each side, job done
- or use another spare seatcalmp (with the lip filed off) on your seatpost and a longer bolt.
- or use p-clips, either on the frame seatstays or a bit one round the seatpost
- or use a single (or both if there's room) rack stay mounted to the existing seactlamp using longer bolt
- or use a single rack stay and bolt to the brake/seat stay bridge if your frame has one
- or a long shot, try a LBS, Salsa aren't the only people who make those clamp adaptors.
I have a seat clamp rack mount spare ( bought 2 ) if you are anywhere near Todmorden[1] for 31.6 seat posts so 34.x from memory
Paul.
[1] So unlikely to be helpful
TBH I'm sure my LBS will have a generic one anyway but I suppose I'll have to accept a non-salsa one. And save some cash! 🙂
Very kind Somafunk, but wrong size, I need 32mm. Also Paul - I think I can get same from LBS.
No bother, I'll throw it back into my box o' bits 🙂
If it makes any difference I have bought a couple of generic ones and they work absolutely fine, no problems.
