Where do you get sh...
[Closed] Where do you get shock 'bearings' from?
[#1758084]
I think I mean bearings, not bushings - I'm after the bit that pushes into the eyelets, and is in 2 parts for each end, and comes into contact with the frame mounting, and is made of aluminium. I'm after a set for a Fox Float R, cheers Martin
Posted : 01/07/2010 10:47 am
Martin - they're normally machined bits of aluminium not actual bearings I think? Mojo may be able to help but they could be frame specific.
Posted : 01/07/2010 10:49 am
[url] http://www.tftunedshox.com/Miscellaneous/Mount-Kits-and-Bushings [/url]
Posted : 01/07/2010 10:50 am
BETD (I asked them, just never got arround to ordering them) you need the 2 top hat shaped bits and a bushing that presses into the shock itself.
The bushing should be replaceable 2-3 times before the aluminium bits are worn.
Posted : 01/07/2010 10:51 am
thanks guys
Posted : 01/07/2010 11:00 am
