My seatpost clamp bolt on my controltech seatpost has ronuded off and it appears to be an m7 bolt.
anyone know where i can get an m7 ti bolt from?
Would you really want Ti there?
I know I wouldn't
Why not?
never had a seatpost clamp fail on you then?
I've had a steel one shear off on a layback a few years ago
No but is Ti more likely to fail over stainless or cromo?
I looked hard but couldn't find one either, but when/if you find one, please email me, as I want one for my I-Beam.
Cheers uplink. Thought there would be an endless discussion on the merits of ti vs steel when all i asked is a simple question of where i can get one from
Bugger, I need a shorter one...
Whaddya expect!!?!!?
sv - more likely to shear IME
What length i forgot to look !
Think i may have a good quality socket cap here but not Ti
J
Cutting ti bolts is a proper chore! Only did that once!
Put two nuts on the bolt and tighten together.
Hold nuts in a vice (fnarr)
Cut off unnecessary bit with an angle grinder
file end to remove burr
remove nuts
5 mins max
