Goggle search came up with nowt 🙁
I might have one in my tool box from my Enduro, looks a bit like an alloy wheel, only way I can describe it!!
I can check tomorrow and post a pic if you like?
I just bought a Pro set 'Wagon wheel' one off eBay, but it has an offset hole?
If the bolt hole is in the middle of yours & its 1 1/8" then it should be fine.
A pic would be nice, thanks.
Not sure if the hole is offset or not, I'll check now otherwise it'll bug me!!
I might have one too - might take me 48hrs to get to the shed though, as I'm not going out now and it's Mrs STR's burfday tomorrow
That looks like the one I just bought.
Maybe mine will fit???
Slightly concerned as my steerer is carbon......
I had it on for quite a while, only changed as I bought a Thomson X4 stem and wanted the red faceplate & top cap.
Don't see why it wouldn't fit yours, carbon steerer or not?
Might be worth a trip to local Spesh lbs and see I've they have one.
The offset hole one (the one with spokes) is for their stem that has a shim in allowing you to set different angles. I've got one fitted to my Inbred that came with my Stumpjumper. You shouldn't fit that to a normal stem.
Have you looked on eBay? I sold an old Specialized top cap on there and there were a few others on at the same time. The one I sold was just plain black with Specialized written in white. Think I got about a fiver for it!
